GTS question
Old Oct 22, 2023 | 11:14 AM
sbeamer's Avatar
sbeamer
Default GTS question
Is there a dedicated area / post just for the new GTS radio ?
Old Oct 22, 2023 | 03:06 PM
Dsm Limited's Avatar
Dsm Limited
Right here is fine.
Old Oct 23, 2023 | 08:16 AM
Fireball Jack's Avatar
Fireball Jack
The GTS is not new, been around since 2019. The 2023 has the new Infotainment system running Skyline OS.
Old Oct 23, 2023 | 10:12 PM
sbeamer's Avatar
sbeamer
I have not heard of that one yet.
Although I did figure out some of my questions from reading and trying different things. I found my AM and WB. Also figured out why I could not switch back and forth from FM to USB.
Now,... I need to find out about this Skyline thing.
Old Oct 24, 2023 | 02:48 PM
cycle7447's Avatar
cycle7447
Community Influencer
Curious - why could you not switch back and forth from FX to USB.
We are all here to help. I recall you asking that question here and several of us provided a response. It is very helpful when you share what worked - or, if you did something totally diferent. That helps us all.
Thanks
Old Oct 25, 2023 | 06:56 AM
Fireball Jack
Skyline is what is in the new 2023 CVO's it is gauges and radio all in one. It is also much larger than the GT or GTS. Using the Harley price Multiplier my guess would be they are $3500-$4000.
Old Oct 25, 2023 | 08:41 PM
sbeamer's Avatar
sbeamer
Sorry. My bad.
So it seemed, no mater what I did, if I switched away from FM to USB, I could not get back to FM. So I was goofin around last weekend and I had a thought which turned out to be the fix ! I erased the USB icon in the favorites and replaced it with a new icon. And that worked! So I put a different jump drive in and then it did not go back to the USB icon again. So put the other jump drive back in and it would switch back and forth with no problem.
I know,.. long winded story. Moral of story,...... If you change the jump drive you have to re-save the icon in the favorites, because it only recognizes the drive that was "last" saved.
Old Oct 26, 2023 | 11:31 AM
cycle7447's Avatar
cycle7447
Great - thanks. Believe we all learned something from you.
larry gaddie
Milwaukee Eight (M8)
May 19, 2021 01:08 PM
Darrell Wade
Audio Systems
Mar 14, 2014 11:22 AM
Mortified
Aug 17, 2013 08:03 PM
harley-jones
Sep 17, 2008 08:15 PM
