How do you like those Beyma's? Was the install as easy as it looks- Remove the pods completely and do they bolt right in or is there a mounting bracket needed?
Those are the Biketronics pod eliminator brackets the Beyma are on.
The Beyma are a dam good sounding speaker. Good enough they resided in my fairing for 5 years. They were paired up with a set of horn tweeters in the grills.
Hey Cshocker, you and Babyboy have got me thinking about some configurations when I wind up trading bikes (23 Ultra Limited).
First question I have is did those SDs kill your FM reception? I have a few stations I like to listen to for local events and such and would hate to lose them, but as in most things you gotta deal with trade offs.
On my 2010 I had to spread my amps out in three different locations. Since I had CB, iPod, and Bluetooth modules under the fairing that only left me room enough for the Arc 600.4 amp and the Arc PSM DSP. I think I'll keep the bike stock for a while but at some point I may put my old stuff back in. As far as equipment goes I have the Arc Moto 600.4, SD 800.4, Kicker PXA300.4 and the Arc PSM. Is there any way for all that to fit into a 23 batwing fairing?
If you swap out the stock amp tray you will be able to put the 600.4 and 800.4 along with the PSM. Depending on the size of kicker amp you could possibly stuff that in the clutch side cubby
