2024 Remote power amp connection?
Old Mar 15, 2024 | 08:27 AM
T3ch3ad's Avatar
T3ch3ad
6th Gear
Default 2024 Remote power amp connection?
With the new models not having the accessory cig lighter power connection, what are people using for remote amp wire connect to power on the amp?
Old Mar 15, 2024 | 10:10 AM
jayrod654's Avatar
jayrod654
4th Gear
I got a kit from Carlos at NVS Audio. The way his kit works, the DSP is plugged in under the seat to the accessory plug which is "keyed." Off the DSP is a blue remote wire that connects to the amp. Other than NVS, I'm not sure of other companies offering kits for these bikes yet.
Old Mar 15, 2024 | 10:28 AM
T3ch3ad's Avatar
T3ch3ad
6th Gear
Thank you for that. So that kit is using the heated gear plugs to power the DSP and the DSP is sending the remote power to the amp on power on. Makes sense and thank you. I wish there was a plug under the front fairing though. Maybe one of the harnesses under there offer accessory power. I will keep searching.
Old Mar 15, 2024 | 11:18 AM
jayrod654's Avatar
jayrod654
4th Gear
Not the heated gear plugs, but a big accessory plug on the same plate as those heated gear plugs you are referring to. It has a rubber plug in the end of it.
sierra72509
Audio Systems
Jan 8, 2022 10:06 AM
royston
Nov 30, 2020 06:03 AM
DoubleD8
Audio Systems
Apr 14, 2019 04:32 PM
Kawickrice
Audio Systems
Aug 12, 2017 12:21 PM
shortride
Aug 22, 2010 04:58 PM
