Need help
Old Mar 28, 2024 | 04:57 PM
EZE77TX's Avatar
EZE77TX
6th Gear
Default Need help
I'm installing the Soundstream Reserve HDHU14+ in my 17 RGS. Already had a RF aftermarket amp and fairing speakers hooked up to factory hu. My question is should I use RCA's on new Hu or just use same wiring setup I had with the old hu? Also will I need to reset any gains or hp, lp on the amp? TIA
Old Mar 28, 2024 | 09:24 PM
chopper_man's Avatar
chopper_man
RCA's and yes, you need to adjust gains, preferably in a means to see clipping. Bypass is set you your speakers capabilities, so if those are not changing you should be good.
Old Mar 28, 2024 | 10:49 PM
EZE77TX's Avatar
EZE77TX
6th Gear
Would that RF amp(TM400x4ad) be enough power for a pair GZ yellow basket NEOs in the fairing? Will be running it bridged. I just want to be one and done if you know what I mean. I also have a Hawg Wired RS4004 amp from their Six Pack set up if that's any better than the RF.
FLYINGBROKE
Audio Systems
Apr 12, 2023 06:58 PM
tjfisher3
Audio Systems
Jun 17, 2020 12:03 PM
torchmaster
Audio Systems
Feb 14, 2018 07:53 AM
WallyWhite
Audio Systems
Nov 11, 2015 10:03 AM
Briguy1
Audio Systems
May 12, 2015 06:37 AM
