Mmats Speakers X Stinger amp install help
Old Jun 17, 2020 | 10:18 AM
tjfisher3's Avatar
tjfisher3
1st Gear
Default Mmats Speakers X Stinger amp install help
I have an 09 Street Glide with an aftermarket jensen headunit. Im looking to upgrade the audio system. I have bought a stinger spx700x4 amp and 2 mmats 601cx speakers for the front fairing. I already have 2 6x9 polk audio db691 speakers in my saddlebag lids. My question is what else do I need to complete this install? Do I need the head unit flashed? Do I need a line leveler? Etc.. Ive read so many forums on here and I can’t find anything about older bikes.
Old Jun 17, 2020 | 10:21 AM
decencyxdefied's Avatar
decencyxdefied
you dont need to flash an aftermarket headunit. hook all that **** up get to jammin
Old Jun 17, 2020 | 10:26 AM
jory434's Avatar
jory434
No you will not need a flash or line levelers. You will need speaker wire, 6.5 speaker adapters for your fairing, rca cables from the deck to the amp for both 1/2 and 3/4 channels and 8 gauge power and ground wires from the battery to the amp. Also some spade connectors and a little wire to power the amp from the remote wire on your deck.
The line leveler/flash requirement is only gonna be for the '14 and up bikes.
Old Jun 17, 2020 | 10:35 AM
tjfisher3's Avatar
tjfisher3
1st Gear
Thank you guys for clarifying all that for me. Should be an easy install for me then. Appreciate yall.
Old Jun 17, 2020 | 10:41 AM
Fireball Jack's Avatar
Fireball Jack
That should sound great! Report back!
Old Jun 17, 2020 | 12:03 PM
SBates08's Avatar
SBates08
Make sure to add a 40 amp inline fuse on your 8 gauge power wire....somewhere close to the battery.
scryle205
Audio Systems
Jun 28, 2019 10:28 AM
benson1603
Audio Systems
Feb 9, 2019 01:54 PM
BrysZ
Audio Systems
Oct 27, 2015 09:28 AM
b_townchops
Audio Systems
Mar 19, 2014 07:14 PM
Grunt66
Nov 29, 2009 02:49 PM
