Hello
I am trying to install a 4 channel amplifier KAC_M3004 by Kenwood. I am unclear how to hook up the outputs.
Here is the amp output...
RMS POWER Output 4Ω: 50W x 4
RMS POWER Output 2Ω: 75W x 4
RMS POWER Output Bridged: 150W x 2
I want to only connect my 2 J&M Rokkers Fairing speakers at this time which are 2 ohm.
Can someone help me to determine how to connect this amp to 2 channel 2 ohm speakers.
I am very ignorant about stereos so please be patient with me. If there is any other information you require please let me know.
Thank you for your help!!!
Bryan
Not a problem. Simply wire your speakers to the front channel of the amp. The back channel will accommodate two more speakers in case you want to expand your system. Both speakers will receive 75 watts rms per speaker. That's pretty much all the JM speakers will handle.
I have this AMP that was apparently on my bike when I bought it used and not connected. anyone know how to correctly wire it up. I have not seen one before with the input as "+" only. Also not 100% sure what the "com" port is for...
Any help would be greatly appreciated!!
Also if anyone knows how to get in touch with the guys at Street Star Designs that would be helpful too.
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
