2004flhtcse rockford amp install
Old Mar 18, 2014 | 08:31 PM
b_townchops's Avatar
b_townchops
Default 2004flhtcse rockford amp install
Alrighty wanting to install this amp and 6.50 inch speakers is there a special harness to wire this or can I tie into existing wiring looking at the pbr300x2 with either rockford polk or boston acoustic speaker also wanting the yaffee install kit butnot sure if you xan just order it according to there website. Any info would be greatly appreciated also was gonna use the existing headunit for now.
Old Mar 19, 2014 | 10:47 AM
UltraNutZ's Avatar
UltraNutZ
you'll need to run power and ground wires back to the battery location
you'll tie your head unit speaker outputs (currently connected to your stock speakers) to the speaker wire inputs on the amp
run speaker wires from amp back to speakers
you will also need adapter rings for the 6.5" speakers in the fairing.
Old Mar 19, 2014 | 07:14 PM
b_townchops
Thanks for the reply any speakers that you'd recommend
CHIPMOVER
Audio Systems
Jan 28, 2015 11:18 AM
Eshaw301
Audio Systems
Dec 29, 2014 11:22 AM
Kingfever
Audio Systems
27
Dec 24, 2013 03:44 PM
longrides
Audio Systems
Aug 14, 2013 08:13 PM
AngryAmish1163
Feb 4, 2011 12:35 AM
