Bin Files
Old Apr 26, 2024 | 07:56 PM
ShoreRider's Avatar
ShoreRider
Default Bin Files
Forum Audio Gods:
I went out today to look at which .bin file is loaded on my '15 CVO Street Glide. I recently installed GZ Yellow Baskets in the fairing and DD Audio VO-XN6X9a's in the lids. They are driven by 2 SD 800.4 EVOX2 amps running in bridged mode and gains set for 230w/ch. I also have an HKI Mini DSP installed as well. I did not have a flash done as there are no shops near me (Memphis) with that capability and after talking to the techs at my dealership, I didn't get a warm fuzzy from them that they even knew what I was talking about.
As I was going through to determine which .vin file was loaded, I noticed an option to load a .bin file from USB. After doing my homework here in the forums, it appears as though the 135_off.bin and the 135_on.bin are the files for the 8/2 flash. I'd like to see if this bin upload capability actually works. Or is this just a capability to load the files into the HU so they are there for use when flashed properly?
Does anyone have or know where I can get the aforementioned bin files so I can dump them to a memory stick and see if it actually works?
Old Aug 17, 2024 | 10:17 AM
JU2012FXDWG's Avatar
JU2012FXDWG
To do what you want you will need to buy this tool and run it on a windows laptop.
https://technoresearch.net/collectio...laris-hd-audio
Old Aug 17, 2024 | 10:37 AM
JU2012FXDWG
For a detailed, educational and easy to understand explanation of the .BIN files listen to Volunteer Audio on YouTube.
Old Sep 3, 2024 | 04:28 PM
Grabbin Asphalt's Avatar
Grabbin Asphalt
2nd Gear
I have the 135_off bin, I heard it doesn't change from off or running but it CLEARLY sounds better when off.
I'm looking into another flash before I try a completely new head unit.
Freak Show
2014-2024 Touring Models
Aug 4, 2023 03:13 AM
Ultra_RB
Jun 5, 2023 02:53 PM
RiderX
Oct 30, 2020 02:35 PM
PDXharleysled
Screamin Eagle CVO Models
Jan 7, 2020 11:49 PM
