Speaker specs
Old May 25, 2024 | 06:07 PM
CookUltraClassic's Avatar
CookUltraClassic
Default Speaker specs
Hey guys.
I’ve got a 2005 Uktra Classic. I just use the fairing speakers.
I just replaced my head unit with a Rockford Fosgate PMX-HD9813. The plug and play radio. I like it, but it isn’t pushing the Boom! audio 8pm speakers that I have.
im trying to decide if I need to get an amp, or just different speakers.
im thinking a better pair of fairing speakers should be all I need.
This RF head unit should be PLENTY loud enough, but with these Boom! Audio speakers it’s barely loud enough to hear at speed.
the radio was expensive. I don’t have much left in my budget.
can anyone suggest a pair of speakers that will mount in my batwinf fairing and make plenty of volume and clarity?
there has gotta be something that is $300 or less that will be what I need.
thanks in advance for your help
Old May 25, 2024 | 09:28 PM
JMJOHN's Avatar
JMJOHN
Sponsor
Yes sir ,,, a set of these ROKKERs should do the trick AND if you add an amp at a later time, the ROKKER speakers will still handle it ,,,,
https://jmcorp.com/JMC-ROKKER-658-Fa...de_p_1409.html
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Old May 26, 2024 | 10:08 PM
CookUltraClassic
Awesome!! That’s just about the exact advice I was looking for when I made this post. Thanks dude.
I take it that the head unit will produce considerably more sound and volume from
these 200w 2ohm speakers than it does from a 50 or 75W 8ohm speaker….. right?
Old May 26, 2024 | 10:17 PM
CookUltraClassic
got a pair ordered and on the way. Exactly what I was looking for. Thanks for the help
Old May 26, 2024 | 10:24 PM
CookUltraClassic
What amp do I want if I decide to get one. The Rockford fosgatw head unit says it will provide 50w per channel at 2ohms.
so there is room for amplification to really get the most from those speakers.
what’s a decent AFFORDABLE amplifier that can push about 130 W per channel that will fit inside the fairing.
any suggestions?
thanks again
Old May 26, 2024 | 11:15 PM
JMJOHN's Avatar
JMJOHN
Sponsor
Cook ,,,
first of all make sure that you save the RCA output adapter that came with that Fosgate radio ,,,,,,
then when you are ready ,,, I would install this JMC ROKKER amp ,,,,,, https://jmcorp.com/JMC-ROKKER-400w-4...de_p_1450.html
when you install the amp, also add these rear trunk pod ROKKER speakers ,,, https://jmcorp.com/JMC-ROKKER-XT-525...tra_p_205.html
Old May 27, 2024 | 05:48 AM
HD_noobie's Avatar
HD_noobie
Why do you think you have 8 ohm speakers?
Why do you think the RF head unit should be plenty loud?
Just speakers aren't going to make the difference you may be looking for.
gadawg31
Audio Systems
Nov 29, 2023 08:55 AM
eross318
Audio Systems
Nov 3, 2016 11:14 PM
sevitz5
Audio Systems
20
Nov 29, 2015 04:42 PM
scooter_trash_1
Audio Systems
Jul 26, 2013 05:22 AM
Nilsa210
Feb 22, 2007 09:02 PM
