Adding an Amp
Old Aug 28, 2024 | 01:41 PM
rolling_again's Avatar
rolling_again
Default Adding an Amp
So, I added an amplifier to my 2018 FLTRU. It is a Hogtunes REV240-RM 4 channel amplifier. I have looked around here a lot and everything i see is people either using a BT155 line leveler or having the Infotainment system flashed. Currently, the system does not sound bad with the amp installed and Hogtunes told me I did not need a flash if I had an ultra with the fade ability built in, which I do. I guess I am just curious as to what other peoples experience is with a flash on the system and if it is worth the $70 they now charge for it?
Thanks in advance
Old Aug 28, 2024 | 05:17 PM
Dsm Limited's Avatar
Dsm Limited
I can't tell you how to spend your money. If it were my money, it would be flashed. If you like the way it sounds and performs, leave it.
Old Aug 29, 2024 | 09:28 AM
rolling_again
Thank you DSM that is the kind of answer I was looking for
Old Aug 31, 2024 | 07:54 AM
rolling_again
Got the system flashed and man does it sound better! I had the dealer down in Dalton, GA do it and they were great to work with. I hadn't realized it but I picked up a nail somewhere and they found it, most likely from my work parking lot, replaced the tire, stabilizer and flash for $550. Great independent dealer with great staff
Tire had 9200 miles on it so it was time anyways. I was procrastinating.
Old Aug 31, 2024 | 11:22 AM
Dsm Limited
Glad it worked out for you. Was it worth the cost of the flash?
Old Sep 2, 2024 | 02:00 PM
rolling_again
Absolutely!
capnkirk
Audio Systems
Dec 15, 2018 12:49 PM
e6fmf
May 23, 2018 05:37 PM
zxport123
Audio Systems
May 18, 2016 08:24 AM
fournierrandy
Audio Systems
13
Dec 14, 2015 09:20 PM
nascarteets
Audio Systems
Jun 16, 2014 10:12 AM
