Nav Menu
Old Sep 17, 2024 | 09:33 AM
NHBAGGER's Avatar
NHBAGGER
Default Nav Menu
21 cvo trike with stock head unit. Turned on navigation and the nav menu was gone except for 'your location' which was correct.
How do I restore?
I did have an amp installed and a flash done. No idea if it worked before that.
Old Sep 17, 2024 | 12:36 PM
cycle7447's Avatar
cycle7447
Community Influencer
Does the radio and everything else work? If so, you can download the software off of the Harley site and restore everything
Old Sep 17, 2024 | 01:56 PM
NHBAGGER's Avatar
NHBAGGER
Seems to be okay. Pretty much use a flash drive. All the info stuff works.
Old Sep 17, 2024 | 04:45 PM
Ssitruc's Avatar
Ssitruc
Who flashed your head unit for the amp? Maybe have them check to see if somehow they inadvertnely disabled Nav... or something. I think if Nav was disabled you would just have a large compass instead. But if it was working before "they" flashed it for an amp, and now its not... they need to straighten it out.
Old Sep 18, 2024 | 05:11 AM
cycle7447's Avatar
cycle7447
Good advice - I missed the note that said he has an amp installed and flashed.
Old Sep 18, 2024 | 09:03 AM
NHBAGGER's Avatar
NHBAGGER
Well the location works and the location map comes up. It appears it's just the menu options I've lost.
USMCShepherd
Audio Systems
Feb 28, 2024 05:45 PM
dbld
May 28, 2018 02:24 PM
zigzag930
Audio Systems
Jun 9, 2017 03:44 AM
Loop4re7
Feb 1, 2013 07:25 PM
