4 ohm stereo with 2 ohm speakers...
Old Apr 2, 2025 | 02:18 PM
HD_noobie's Avatar
HD_noobie
Originally Posted by BlackPearl#1
Not sure I really agree with that either, but you can easily lower the speaker ohm load that the amp sees by wiring the speakers in either parallel or in series.
Kris
sure you can change the ohm load at the amp by adding speakers, but that's adding speakers. The OP could do the same.
Old Apr 3, 2025 | 06:51 AM
Babyboy's Avatar
Babyboy
Don't get completely stuck on the #s.
The resistance of a speaker is measured at a resting state. A speaker is an electric motor where the resistance is constantly changing as the voltage is applied and varied, creating sound.
You put said speaker into an enclosure and the working resistance will change again,it is called box rise.
So your 2 ohm speaker and 4 ohm stereo will play fine together.
Old Apr 3, 2025 | 12:42 PM
Buelligan666's Avatar
Buelligan666
Technically it's impedance, not resistance. But that's just being snarky I guess...
Old Apr 3, 2025 | 12:51 PM
Babyboy's Avatar
Babyboy
Not to split hairs BUT impedance is the AC equivalent to resistance and audio output is an AC SIGNAL 🙃🙃
Old Apr 3, 2025 | 01:51 PM
Buelligan666
Yes, that's why it's impedance. Just nomenclature. Lol.
Old Apr 3, 2025 | 03:27 PM
Notgrownup's Avatar
Notgrownup
Ohm my god i'm confused.
Old Apr 6, 2025 | 01:58 AM
wlbowers's Avatar
wlbowers
You can get a 2 ohm resistor that is a wattage rating equal to the 50% of the amp output and wire it in series with the speaker. Some amps will tolerate a lower impedance some won't.
Search amazon for 2 ohm 25 watt resistor
FYI I worked on car home and pro audio since 1969. When you let the smoke out they don't work as well. When radios were over $300 I made good money repairing them. Now their throw aways.
kojak
Audio Systems
Jan 8, 2022 03:10 PM
bigreds1963ss
Audio Systems
Mar 24, 2015 10:04 PM
escalade6103
Jul 7, 2014 08:23 AM
KYBill
Jun 18, 2014 09:33 AM
notrailers
Touring Parts
Mar 29, 2011 12:08 PM
