Ok fellas,
I have a 2017 Electra Glide, I upgraded the front fairing speakers. check
A friend gave me a Boom! Audio amp #76000277B.
1. Will this mount in the fairing?
2. Do I need an adapter cable?
UPDATE:
The cost to install this amp is too expensive.
So my next question is what amp can I just add as in-line AFTER the head unit. Like old fashion amps in cars.
Add the amp after radio in-line with speakers. Then I don't have to have radio flashed.
UPDATE:
What is "too expensive" to have installed?
To get the best sound, you need to get the radio flashed. And yes, it's easy to add aftermarket amp in after the amp with no cutting of factory wires.
This amp won't fit in fairing. This amp has to be mounted in saddlebag. I saw the IPB at the dealer. I would have to have wiring/cable ran from head unit to saddlebag and then back.
