Mixing Speaker Ohms
Old Feb 24, 2026 | 05:39 PM
rblahetka's Avatar
rblahetka
Question Mixing Speaker Ohms
I have a Cicada FLX1400.4. I have GZ yellow baskets up front. Can I run a pair of 2 ohm speakers for the rear?
Old Feb 24, 2026 | 07:00 PM
Babyboy's Avatar
Babyboy
You can mix ohm loads on an amp as long as they are a pair of channels ex channel 1&2 @4 ohm channel 3&4 @2 ohm.
As long as you do not go below the load rating of the amp. Most 4 channel amps are good at 2 ohms in stereo or 4 ohms bridged.
Old Feb 24, 2026 | 07:37 PM
rblahetka's Avatar
rblahetka
Thanks. That being said, the GZ’s in front are 4 ohm. I ordered a set of Cicada CXX69.4 in 4 ohm. Would I be better off returning and getting them in 2 ohm? Amp does 200x4 in 4 ohm or 350x4 in 2 ohm. Or, make everything 2 ohm?
Old Feb 25, 2026 | 09:32 AM
Babyboy's Avatar
Babyboy
The CXX69.4 have a warmer tone over the 2 ohm. I have used both versions and perfer the sound of the 4 ohm on the 1400.4.
If you were only using the FLX700.4 I would suggest the 2 ohm speaker.
Make sure you have a 4 guage power and ground going to that amp they like all the DC power you can give them it makes them happy and your output to the speakers will show it.
BTW what part of Illinois are you in?
Old Feb 25, 2026 | 09:45 AM
rblahetka's Avatar
rblahetka
Good to know. I ordered the 4 ohm and was second guessing myself due to the RMS rating on them. 4 gauge is from the litho battery all the way to the amp. Hertz DSP. I'm in Schaumburg. I visited you years ago when I had my black Street Glide and had brought up some 12 ounce refreshments.
Old Feb 25, 2026 | 09:51 AM
Babyboy's Avatar
Babyboy
Right on.
My apologies for not remembering. I talk to so many people week to week it gets hard to keep track of everyone including myself LOL.
If you need a set of those CXX69.4 sooner than later I have a set sitting on the shelf
Old Feb 25, 2026 | 09:55 AM
Jake707's Avatar
Jake707
You noticed a difference in tone between the 2 and 4 ohm versions and not related to amp/power tuning? I thought they would be the same just the 2 ohm was more "efficient" and could take a bit more power.
Old Feb 25, 2026 | 10:06 AM
Babyboy's Avatar
Babyboy
The 2 ohm and 4 ohm speaker take the same power but at different ohm load.
After tuning multiple bikes in different configurations of 2 ohm and 4 ohm speakers I myself can hear the difference between them BEFORE tuning. The 2 ohm will take a different crossover settings than the 4 ohm for starters and the highs on the 4 ohm are not as screechy as the 2 ohm.
King420
Audio Systems
Jul 15, 2017 01:32 PM
prezflyr
Jan 7, 2015 04:17 PM
SG1858
2014-2024 Touring Models
Jul 10, 2014 05:07 PM
mtgriz
Gear and Other Items For Sale
Apr 11, 2010 12:23 PM
bulldogmoe7
Oct 12, 2008 04:00 PM
