Preamp outputs
Old Jun 15, 2011 | 08:09 AM
mking7's Avatar
mking7
Default Preamp outputs
Looking into aftermarket head units and don't understand the difference between 2 and 4 volt preamp outputs. Does it matter?
Will be running the Hawg Wired 300watt (4x75) amp with 2 6.5" and 2 6x9's.
Looking at the Sony digital media receivers.
Old Jun 16, 2011 | 06:06 AM
Shakeydeal's Avatar
Shakeydeal
It means that the 4 volt output will drive the amp more efficiently. Unless you have an amplifier with really low input sensitivity, it really shouldn't matter. You will just achieve the same volume at a lower setting with the 4 volt unit. Either one should drive the amp to clipping sufficiently.
Shakey
Jamestheron08
Audio Systems
Dec 11, 2016 04:05 PM
ericl
Audio Systems
Oct 7, 2016 05:05 PM
pktrusty
Audio Systems
Jun 9, 2016 10:51 AM
Angelsbass
Audio Systems
45
Mar 31, 2016 10:46 AM
Madcop
Audio Systems
Oct 10, 2015 08:29 AM
