FLTRX Boom Amp problems
Old Sep 21, 2011 | 08:21 AM
jdmiller's Avatar
jdmiller
Default FLTRX Boom Amp problems
Purchased the boom Amplifer for the FLTRX, Part#76000169 and The Harley dealer can not get it to power up the rear speakers to a tour pac. What could they be doing wrong? The pod speakers work ok back in the normal configuration. harley has informed the shop that this amp is designed for the front/rear speaker configuration.
Old Sep 21, 2011 | 01:08 PM
UltraNutZ's Avatar
UltraNutZ
the boom amplifier will drive the 4 speakers with the purchase of the 69200106 wiring harness
Old Sep 21, 2011 | 07:55 PM
jdmiller's Avatar
jdmiller
the non ultra overlay harness has been installed, So the other harness is also required.
Old Sep 22, 2011 | 07:08 AM
UltraNutZ's Avatar
UltraNutZ
those guys should have known that. :-)
Old Sep 26, 2011 | 09:54 AM
jdmiller's Avatar
jdmiller
do you have a picture of the schematic for the other harness? Also some installation directions?
Old Oct 4, 2011 | 10:18 PM
mrbs's Avatar
mrbs
1st Gear
Default boom
hey i have a 11 fltrx and have the same problem. front booms work awsome loud clear and crisp. followed the wiring diagrams and still nothing out of the saddle bag lid speakers. im goin to call hd in the am and see if what they think. if i happen to make them work, i will post it up. good luck
Old Oct 5, 2011 | 07:04 AM
UltraNutZ's Avatar
UltraNutZ
http://www.harley-davidson.com/en_US...ts/-J05266.pdf
Old Oct 5, 2011 | 12:25 PM
jdmiller's Avatar
jdmiller
By looking at the wiring, there is no output for the rear speakers. If we assume the 6A/B is the input to the Amp and the output for the front speakers are there from the amp. It looks like there would have to be some connections made on the back of the amp for the rear speakers to plug into the rear speaker POD harness that initially plugs into the overlay harness
. Any comment or theories?
Old Oct 6, 2011 | 07:47 AM
UltraNutZ's Avatar
UltraNutZ
look at page 2 of the pdf. There are specific instructions for connecting the 69200106 harness to the black plug on the back of the radio. Pins have to be removed from the black plug and replaced with pins from the 69200106 harness
Old Oct 6, 2011 | 07:50 AM
UltraNutZ's Avatar
UltraNutZ
just to clarify; you do have the 70169-06 overlay harness installed?
