07 RoadGlide
Old Oct 19, 2012 | 11:45 AM
jnd42697's Avatar
jnd42697
Default 07 RoadGlide
I just purchased a Hawg Wired system and I need some info. This is what I purchased. The amp are model SC1502 and 2 of the GT75 the Speakers are CX504-7. My question is with this system being 4 ohm and my stock speakers being 2 ohm, can I run the stock speakers straight of the stereo and these two speakers with the amps like it is set up or do I only have the option to do one or the other set of speakers.
Thanks
Jeff
Old Oct 19, 2012 | 12:27 PM
UltraNutZ's Avatar
UltraNutZ
yes sir you can run (what I'm assuming is rear or lower speakers off the radio) and run these off the amp.
Old Oct 19, 2012 | 07:26 PM
Brusier1028's Avatar
Brusier1028
Yes you can. The amps supply power to your new speakers. All you are using the stock radio for is signal input to the amp so it can amplify it.
Old Oct 19, 2012 | 07:28 PM
jnd42697's Avatar
jnd42697
Thanks guys, been a while since I played with stereo equipment.
vlegath
Oct 11, 2013 07:59 AM
twistr
Audio Systems
Nov 19, 2012 05:30 PM
dunnp650
May 17, 2010 05:18 PM
mca1989
May 15, 2010 10:51 PM
Badbagger
Feb 10, 2008 11:18 AM
