How's this setup?
Old Oct 22, 2012 | 09:18 AM
Rockrivr1's Avatar
Rockrivr1
Default How's this setup?
I have a Hoppes Quadzilla fairing on my RKC and I've been going through all the threads on this board and other places to find a setup that will fit into my price range. I went to a couple audio places and the best quote I received was $1200. A little high for me, so I'm going to try and do this myself over the winter. Figure I can give it a shot. What's the worst that could happen.
So this is what I'm thinking of doing.
Replace the head unit with a Sony MEX-BT3000P. I like the Bluetooth option and the Satellite radio setup. It has a 5 star rating and is around $100
http://store.sony.com/p/detachable-f...n/p/MEXBT3000P
Replace the 4 existing Jensen marine speakers with 4 Polk MM521 5 1/4th Coaxial speakers. The way the speakers are mounted into the fairing, there isn't a way to put bigger speakers into it unless they get mounted from the outside.
http://www.polkaudio.com/products/mm521
Adding in an amp. This is my weak point as I have no experience dealing with adding an amp. Since the speakers are 4 Ohms I've been looking for a 4 ohm amp. Trying to keep my pricing low and still get a quality amp I'm thinking of going with RF PBR300X4 amp. This provides 75 watts per each of the 4 channels. I'm assuming that is enough to get quality sound. I need to research how I want to set this up, but I was assuming 1 channel per speaker. Does anyone recommend a better amp at the same price point?
http://www.rockfordfosgate.com/produ...?itemid=120465
In my research I'm going with the assumptions that I'll need an amp kit as well as various connectors. The Hoppes fairing is a quick disconnect setup that I can take off the bike in about 5 minutes. I'll probably have to drill the fairing to put a second quick disconnect in place for the Amp power. Any recommendations on an amp connector and power package, I'd love to hear about it.
This should keep me in the $600 range. Is this a good setup? Anything you would change? All comments welcomed.
Thanks
Old Oct 22, 2012 | 08:14 PM
Rockrivr1's Avatar
Rockrivr1
No comments? Must be a not so good setup.....
Old Oct 23, 2012 | 06:03 PM
troop's Avatar
troop
I think you will enjoy that stereo very much
Old Oct 23, 2012 | 07:56 PM
Double Duece's Avatar
Double Duece
Im getting the Reckless Cycles fairing, and need advice on stereo and speaker setup also. Im looking at the Pioneer bluetooth cd usb unit with Kicker 6x9 speakers. The cd player is 169.00 and the speakers are 90.00 and the marine cover is 25.00.
Old Oct 23, 2012 | 10:28 PM
floridapoolboy's Avatar
floridapoolboy
The Polk MM series speakers are 2.7 ohms, the RF 4 channel amp requires 4 ohm speakers. If you run the amp with four lower impedance speakers it may clip and/or overheat. Stick with 4 ohm speakers with that amp!
Old Oct 24, 2012 | 04:46 AM
GLACIERPEARL's Avatar
GLACIERPEARL
Definitely a huge downfall of the Polks is the 2.7ohm rating.
Old Oct 24, 2012 | 11:54 AM
Rockrivr1's Avatar
Rockrivr1
DAMMIT!!! How the hell did I miss that. Granted I'm a big time novice with this stuff, but I had thought I had checked that. Glad you guys piped in before I started purchasing this gear.
So that leaves me with another question. The RF puts our 75 watts per channels on 4 channels. Which speaker would work better with this amp.
Hertz - High Energy w/ power handling of 70W continuous power and 140W max peak.
or
Arc Series 502 w/ power handling of 45W continuous power and 90W max peak.
Like I said, I'm a newbie with this stuff. Thinking the High Energy would be a waste as my amp can't push even close to the max level of the speaker. Then again, as far as I know, that may be a good thing.
Thanks!
Old Apr 7, 2013 | 12:53 PM
STREAK's Avatar
STREAK
Resurrecting a somewhat older post, but have a similar question.. was going to pm OP, but figure I will ask more publically.. I purchased a RK w/ a Quadzilla.. want to replace the eclipse head unit and possibly speakers.. I am not looking for an amp at this time (most likely not in future either)... Any thoughts on a head unit that would be good for the Quadzilla (would like USB or aux input.. neither of which are on the eclipse).. also.. speakers seem a bit dull but as many know.. not alot of options for 5" speakers.. thoughts?
Thx in advance..
Wayne
Old Apr 7, 2013 | 05:16 PM
Rockrivr1's Avatar
Rockrivr1
Thx in advance..
Wayne
Hi Wayne. An update from my Quadzilla build is that I gave up on trying to do it myself. There's a number of reasons, but the biggest is that I received gear that I just couldn't fit properly in the fairing. So I returned it and instead sought to find someone who knew what they were doing.
I found a great place that wasn't to far away and the owner spent a good amount of time with me going over what I wanted. He took apart the fairing and started pointing things out. The biggest issue is that the 5" speaker space on the ends is very shallow. Guy indicated that you need to get special low profile speakers for that slot, which eliminates a good portion of the 5" speakers available. He also convinced me that the head unit and speakers I had were good enough and I just needed an amp.
In the end he installed an Arc amp and I really couldn't believe the difference it made. Very happy overall with the sound quality now. Was able to ride on the highway doing 80mph and clearly hear the music and actually feel some of the base.
As to head units, you can fit just about anything in that spot. You biggest issue is the speaker space and what you end up getting.
Old Apr 7, 2013 | 09:45 PM
STREAK's Avatar
STREAK
Thx much for the reply!! Did the ARC mount in a saddlebag, or in the fairing itself? Thanks again and glad you are happy w/ the setup!
