Upgrade head unit?
Old Jan 2, 2013 | 09:41 PM
vhmike73's Avatar
vhmike73
Thanks for the help here UltraNutZ...truly a wealth of information!
I had about the same questions as ratdoc regarding the power each of the speakers would see in the parallel setup; but I was thinking along the way you described in that the amp wouldn't care so much about which actual speaker got what (# of watts).
As for my situation: I need to move to Texas! It's 11 degrees here in Upstate NY right now, and I have no place to work on the bike and won't for a while. Gives me time to think and research though; I AM going to order up the lower fairing pods and will add more parts over the next couple months (while we suffer through winter). As for the Polk db/DXi series speakers, both manuals show a separate mounting plate in their install- modifications would be necessary to that plate, but I think it would help span things properly. I would THINK that either of those speakers should screw into my CycleSounds speaker adapters for the fairing without issue. I do sorta question whether the size of the db651/DXi 650 frame will fit in the CVO lower speaker pods well. It's not a major question, but it won't be answered for certain until I get the pods here. Unless someone A) has the CVO 6.5" speaker pods and B) is using/has used THOSE EXACT speakers and can comment, I'll live in suspense for a while! Worst comes to worse, I can toss the Polks in my Silverado's doors and try some other 4 ohm speakers for the front of the bike. There's so many choices and price points, I HAVE to be able to find something decent without going (much) over $150 per pair.
Next decision is the matter of how to wire the front up; my lowers are currently set up as detachable, but I have only taken them off to CONVERT them to the detach, so I'm thinking that spending extra effort to rig up a quick-disconnect wiring system won't really benefit me. I'll vacillate on that one about 300 times before I actually get around to doing the install though!
I'm still in internal debate about adding a 2 channel-2ohm amp in the TP and running all six speakers at the native 2 ohm loads of the SS (all four fronts as MM651 since it's been well established on the forums that they fit in both the batwing and lowers) then running the rear speaker pods on their own 2 channel amp (also MM651). That's opening up a couple issues for me; first and foremost is losing TP room and second is figuring out how to get signal there and then power and grounding (while keeping the TP detachable).
Ugh!! Decisions, decisions!! Thanks again for sharing all your knowledge!
Old Jan 3, 2013 | 07:42 AM
ratdoc's Avatar
ratdoc
Thanks Ultra! Amazing, as always.
Old Jan 6, 2013 | 08:19 AM
UltraNutZ's Avatar
UltraNutZ
IF, you're not going to take your lowers off, then I would go the route of the DXi650 speakers in the fairing and the lowers. Wire them in parallel to the front channel of the amp at which point will be a 2ohm load. Then simply run your rear outputs from the amp to a pair of MM651 speakers in the pods. This keeps everything at a 2ohm load and won't require the use of another amplifier and you can use quick disconnects for the rear speakers and tuck them up under the seat when not in use.
Old Jan 6, 2013 | 11:30 AM
vhmike73's Avatar
vhmike73
I was thinking that same thing, Ultra...I swear, I really AM a quick study, even though it may not seem so!
Do you have any pics of the new setup for your bike? How did you mount the SS amp (drilled new holes on Scott's bracket, or used zipties?) How does the 310 work with Bluetooth/Pandora (and the latter will depend on your network as much as deck performance)? Not sure upgrading for the Pandora functionality is worth it to me...and last, do you use a satellite radio? If so, which? If it's the Sirius connection kit, does it display more than the XM add-on kit I described?
At least it's 30-something here today!
Old Jan 6, 2013 | 12:23 PM
Aircooled81's Avatar
Aircooled81
Default I agree
Originally Posted by UltraNutZ
depends on what bike you have. If a streetglide then you don't have to worry about the headset communications, passenger pod controls, and cb that you'll lose like you would on an Ultra. There is a huge difference in sound quality in an aftermarket radio vs the stock HK unit. Then you get all the bells and whistles on the aftermarket radio additionally. For example, the Sony DSX-310btx has a face plate that opens to expose a drawer which will hold just about any iPod you can put in it, then there's the equalization thing that is HEADS above the bass and treble settings on the stock HK unit, bluetooth, pandora, etc. The list goes on and on.
Yup. I think 30% sound quality increase is available losing the HK and upgrading to an aftermarket. Keep in mind, if you move to an aftermarket, you'll want a display that can be seen in direct sunlight, and some sort of water protection if you ever might get caught in the rain. I am very interested in the Sony marine grade with the ipod cabinet inside. The boards are coated to prevent water damage and the screen is liquid display so the sun over my shoulder isn't going to prevent reading the display.
Old Jan 7, 2013 | 07:22 AM
UltraNutZ's Avatar
UltraNutZ
I can show you just as many failed marine grade components, both speakers and electronics so I wouldn't focus too much on that aspect of your projects. The key thing is making sure you purchase speakers that do not have paper-type cones or dust covers. The radios, just make sure you get something like biketronics provides with their kits in respect to a water shield for those rain storms and washing the bike. As for readability in direct sunlight, good luck with that. I can tell you that the majority of Sony, JVC, Kenwood, etc. headunits are LCD or LED displays and if you're out in direct sunlight, you'll barely be able to read them. But then again, this goes back to what I stated in a previous post; you shouldn't be looking at the radio while you're riding anyways, that's what your handlebar controls are for.
Sound quality; there is a tremendous difference in sound quality from that HK unit to an aftermarket unit. No comparison whatsoever.
Old Jan 7, 2013 | 07:27 AM
UltraNutZ's Avatar
UltraNutZ
Yes sir I have pics that I took throughout this process and streetglidewalt also have a few that I'd like to get from him as well. I'll get those posted up today hopefully.. got a busy day. I'm not 100% sure on the bluetooth and pandora thing yet. Even on my 09, I never used it. I agree about the upgrading simply for Pandora. I am not using the satellite radio piece either. I have a garmin GPS that displays weather map overlays onto my GPS screen using XM Weather and my iPod has over 1000 songs on it so I really don't see the need in satellite radio at this point nor did I have it on my 09. I did however have it on my 06 RK and loved it.
Old Jan 7, 2013 | 07:31 AM
UltraNutZ's Avatar
UltraNutZ
oh yeah, the bracket I wound up not using mainly because I bought the bracket back when I thought I was keeping my stock HU so it's the amp mount and relocation bracket together in 1 piece. But now that I had everything apart and in my hands Saturday, the SS amp is about 1.5 longer than the bracket on each side so I feel your only 2 options with the bracket are 1.) use large zip ties to wrap around the amp to the bracket or 2.) use industrial strength 3M hook and loop velcro to secure the amp to the bracket.
I'll post the pics of the 2 small brackets I made that attached the amp to the stock vertical fairing brackets.
Old May 15, 2013 | 12:35 AM
Computron's Avatar
Computron
Thumbs up
I second everything UltraNutZ mentioned. The HK deck is pre-2005 technology at best- the Harman Kardon's big "feature" is MP3-CD capability (I had that factory-installed in my 2002 Dodge Ram!). There's no USB functionality, native iPod control or satellite radio, and if you're a fan of HD radio, that's not even possible to add to the HK to my knowledge. You CAN add iPod/Satellite radio, but each requires EXPENSIVE modules and extra-cost cabling (unless you use the HDPDPlus module; at least the cables are PART of that kit). I will say one good thing about the HK radio: the display is very easy to read in sunlight.
Plus, once you buy either the Biketronics or Hawg-Wired's module/install kit, you can swap in any deck that comes along that offers the features you're looking for while retaining bar controls (AND AVC with Biketronics). As he mentioned, the Sony DSX models all feature "TuneTray" which allows you to plug your iPod/iPhone 4S in (though there's no iPhone 5/Lightning connectivity yet) then close the face: it's protected and charges while you go even if you're not using that as your source. Or you can get a cheap high-capacity thumb drive and plug that in inside the TuneTray instead of an i-device, and still mount your iPhone on the handlebars and plug it into the external USB port, retaining full control. If you're interested in satellite radio but don't want to add an external tuner, Alpine makes a cd deck with SiriusXM built in that still includes iPod control and USB functionality!
Point is, you can get all manner of CD decks with MP3 cd, HD radio-ready, native iPod control, Bluetooth connectivity, native Pandora control with an iPhone/Android device, all costing HUNDREDS less than the Harman Kardon "Advanced" Audio AM/FM/CD Radio Kit. (seriously, a GRAND for this thing!?!?!?) You can't add USB functionality or Bluetooth to the HK deck. I'm referring to Bluetooth more for the A2DP functionality (streaming audio) rather than phone functionality, but it's a moot point with HK. There's the higher end of aftermarket features (still cheaper than HK) - decks like this one with motorized, flip-out LCD screens for DVD video or this model that includes Navigation (not sure how the screen being extended works out when rolling down the road though; check with GLACIERPEARL on here for his input, he's running a similar deck. Frankly, it's probably illegal to watch a movie while rolling through the twisties, beyond being just plain DUMB! ). Check this out: Parrot (a big player in Bluetooth systems for automotive use) is marketing a mech-less (no CD) unit that is fully bluetooth compatible and has a built in apps (Nav and Traffic apps included) with a 3.2" screen in a Single-DIN form factor! (However, it's physically a very short depth, so it doesn't appear that it would bolt into either the Biketronics or Hawg Wired deck install kits...)
In my opinion, the BEST part is that if your deck can't handle weather or vibration well, they're CHEAP and easy to replace. The DSX-S310BTX he mentions can be had for under $150 brand new shipped to your door. 30 minutes later (depending on the complexity of your setup, and if how familiar you are with getting in/out of your fairing), you're back up and running with a new deck, and you didn't have to deal with a dealer giving you the runaround, or wonder if the HK was even in stock at the dealer. And if you're out of warranty, you are saving TONS. That "30 minutes" is MY experience swapping decks to verify the Biketronics module I had did indeed fail; I swapped from the DSX-S200X back to my refurb DSX-S100 hoping it was a deck failure, but no dice, it was the BT1002 (older version). (By the way, Biketronics is great to deal with; you can reach them by phone or email and if you email a phone number, the DO call back! You pay a core charge and they mail out a new unit Priority Mail to you, and you're credited very quickly once you send back the faulty part.) Worse comes to worse, you can run to WallyWorld and grab a $79 Sony deck (still much more functionality than the HK) to get you through until the better option actually gets to your door (then you've got a spare deck if anything goes wrong again later- and you're not bankrupt!).
My DSX-S200X (updated to the DSX-S210X now; no Bluetooth, but all the other features of the DSX-S310BTX; this is a dirt cheap price!) has gotten wet (not directly sprayed with water, but rained on, as well as sitting in condensation from morning dew), and I've had no problems with it's performance even though it's not a "Marine" deck. One other nice feature - I can change the deck's lighting from blue to red, so it's a little better match with the gauges in my fairing. It has three 4 volt pre-amp outputs for expansion, and adding XM to it required a $79 universal tuner module and $19 Sony-Specific cable. (Harley wants $500 for their XM module- and that's not counting the $109 cable that's 80% unnecessary wiring just to MAKE their module work on a Non-Ultra bike- the Ultra harness is less but necessary!!). Adding an amp is easier with the pre-amp outputs (as opposed to the line-level setup you'd use with the HK, or having Iron Cross Audio take your HK and mod it to include the pre-amp outputs). Plus your speaker choices expand even if you're not looking to amplify the deck because you can go to any car audio place and find 4 ohm speakers more readily than finding 2 ohm speakers like Harley uses. Without trying hard to find the "best" deals, you can reconfigure your ride to have the latest in technology for less than adding either the iPod or XM modules to your HK (figuring $250 for the universal Biketronics Retro-Radio kit, $150 for the DSX-S310BTX and another $110 for Hogtunes drop-in 5.25" speakers (4 ohm)). For less than the cost of EITHER Boom! Audio module, you've just upgraded functionality and sound quality...and you can eBay your HK and recoup that initial cost or put the proceeds into an amp/6.5" speaker setup and STILL be cheaper than trying to make the HK radio do all the things an aftermarket deck of even semi-recent vintage offers.
As for DISADVANTAGES: Hmm...your bike won't be Bone-Stock. I can't think of any other advantage the Harman Kardon system provides over the aftermarket at this time. I mean, yes- you CAN amplify the system and upgrade your speakers, but the deck is still the limiting factor. One tiny bonus; if you swap the deck, you gain the added 'feature' of the clock display moving to your odometer display! Both Biketronics and Hawg-Wired make plug-and-play modules to EASILY add Sony decks to any fairing bike, as well as Universal kits if you're looking to go with Alpine, Kenwood, JVC, Pioneer, etc. (I focused on HW with those links; BT doesn't post JUST the interface online- their module is part of the install kit). Which company you choose depends largely on how you feel about retaining AVC (Auto Volume Compensation)...BT keeps it, HW doesn't. I've read posts from a couple guys who used steering-wheel interface modules from PAC or Axxess, but they aren't as simple as the BT or HW modules, both of which are plug and play once you've connected your head-unit's harness to them. Another disadvantage is that upgrading WILL get you more features, which as I mentioned regarding the flip-out screen units, can be dangerously distracting (like worrying about cover art or track info when you should be watching the road). But being smart about not paying attention to your display (which is cautioned against in the manual regarding the HK too), and you'll be fine. Oh, and you can't add the spiffy $15 chrome trim pieces available for the face of the HK from Harley, so if you're a big "chrome" guy, that's a disadvantage I guess. Might have to settle for finding a silver head unit!
To quote Dennis Miller: "That's my opinion, I could be wrong."
Excellent! This should be a sticky
Old Jun 4, 2013 | 06:56 PM
Missouri Snowman's Avatar
Missouri Snowman
bump bump
bump
