Ticking sound in headset
Old Mar 4, 2013 | 08:23 PM
YoDA's Avatar
YoDA
Default Ticking sound in headset
When I accelerate on my 2011 EG I get ticking sound in my headset, does anyone know how to get rid of this? Is there a suppressor or something? Yes, I've check the ground and it's solid. I just sold my 03 this fall and it had the same annoying thing, and I notice my 2011 has it too, so it's probably something inherent in the system. I dunno.
Old Mar 5, 2013 | 07:02 AM
UltraNutZ's Avatar
UltraNutZ
have you by chance changed coil, plugs, or plug wires?
Old Mar 5, 2013 | 08:56 PM
WestTexasRanger's Avatar
WestTexasRanger
Yeah, be sure your plugs are if the resistor type.
Old Mar 6, 2013 | 08:04 AM
YoDA's Avatar
YoDA
I had 85,000 miles on my 2003 so I changed the plugs many times. The 2011 however I've only had a few months and have not changed the plugs. Haven't replaced coil or plug wires on either of them.
Old Mar 6, 2013 | 08:12 AM
UltraNutZ's Avatar
UltraNutZ
I would take a piece of wire, wrap it around the outside of the plug for the headset and while you're listening to the headset, rev engine and ground the other side of that wire to something like a headbolt that's within reach to see if it stops. if it does, you have a ground issue
Check the battery ground wire at both ends for corrosion and tightness. You need a good solid ground throughout your bike otherwise you'll get all kinda weird things happening.
Old Mar 7, 2013 | 03:47 PM
YoDA's Avatar
YoDA
Good suggestion, I'll try it this weekend and let you know how it goes.
Christian T
Jul 16, 2015 12:20 AM
Smokey0558
Aug 18, 2013 09:27 AM
easttnrhino
Exhaust System Topics
Apr 8, 2013 10:59 AM
brooklynharley
Aug 27, 2012 08:57 PM
Pass
Jun 4, 2011 03:16 PM
