Better still, explain what you did--those "how to" threads are what make HDF so great. If you didn't come up with this on your own, supply the source of the information you used; payit forward.
1. Can't believe the BikeTronics amp is that small in size........that shocked me !!
2. Did you using HD lower speaker boxes , or aftermarket ??
3. Those lower boxes look incredible with the black contrast of the grills, against the yellow ! Did you add a red pinstripe between the speaker boxes and lowers, ...to match the red stripe on the tank ??
Those BT amps are extremely small in size shocked me to as I was reading specs on them, another shocker to me was the statement at end of product description made in USA and lifetime warranty those two statements carry a lot of weight these days. In my opinion.
Molar man how was the harness that come with the amp was it nice and easy to hook everything up?
I used Harley CVO speaker pods. They are not very expensive. Had a guy paint them for 100.00
I did not do pinstripe but that would be cool.
The harness was easy to use. They sent plenty of clips to crimp onto the harness. I had to crimp them on myself since they really do not know how long your wires have to run. Overall not a bad install.
I saw a picture on their site but couldn tell as much about it with it being all bundled up but it looked pretty enticing for a easy install good to know. For someone in the future.
