Hey guys I'm running my wires for my amp and in ultras step x step instructions he says to mount e ground wire to the triple tree threaded hole just under the radio! If I'm looking at the same hole correctly it already has two little wires in it correct? And if so I will have to take my head unit back out to get to this hole? Any help will be greatly appreciated thanks guys
Wow thanks mine doesn't haw any holes on the front side like that. Now I see why ultra sai you can't miss it lol. Def not on mine lol thanks for the pics
Ok for the ss amp are you guys using the hi input wires and not the blocks? The wires that I got with amp are not the same colors as described in ultras instructions. Just don't wanna mess something up
On newer bikes the threaded hole is on TOP of the triple tree just under head unit, I think there's one on each side. It's kind if a pain in the azz to get to with the HU in place and it's pretty small so you'll have to feel around with your finger to find it. I used a 1/2" long self-tapper with a washer, can't remember the diameter.
Yeah thanks man I just use the same hole the other two wires were in ( hope it's a good ground). Still trying to figure out this wiring thing though
That spot will work as well. The empty hole is the same size and just to the left of the spot you used. They're both tough to get to with big fingers lol. Good luck!
