Wire nuts?
Old May 16, 2013 | 01:57 PM
mhill0826's Avatar
mhill0826
Default Wire nuts?
Are wire nuts good for the connections inside the fairing?
I've used them for pretty much everything else in my limited wiring career without issues, my guess is they would be o.k..
Just wondering if audio wiring would be different.
Old May 16, 2013 | 02:02 PM
Jackie Paper's Avatar
Jackie Paper
Never wire nut anything on a motorcycle or car if you want reliability. Solder, one tight layer of protective plastic tape, shrinkwrap and then a tad of rtv fingered in the openings. Do it that way and I guaranteed it to wake up the junk yard dog in 50 years.
Old May 16, 2013 | 02:04 PM
soft 02's Avatar
soft 02
No wire nuts or scotch locks.
Old May 17, 2013 | 07:06 AM
UltraNutZ's Avatar
UltraNutZ
crimp or solder!
Old May 17, 2013 | 08:35 AM
Meist21's Avatar
Meist21
I use butt connectors............if done correctly and then shrink wrapped you will never have an issue. I would not use wire connectors. It will work itself loose especially on these bikes.....
Bill wallace
Shovelhead
27
Feb 16, 2021 08:00 AM
bobbyjoes
2014-2024 Touring Models
May 5, 2017 08:42 PM
Danielc409
Jul 8, 2013 01:16 PM
1931jamesw
Aug 21, 2011 04:01 PM
pococj
Jun 11, 2005 10:03 PM
