Kicker?
Old May 30, 2013 | 09:04 PM
UltraNutZ's Avatar
UltraNutZ
Old May 30, 2013 | 09:05 PM
UltraNutZ's Avatar
UltraNutZ
ARC makes a good amp no doubt. It all comes down to what you want to spend on your setup..
Old May 30, 2013 | 09:08 PM
Gearheaddrew's Avatar
Gearheaddrew
I will also need an amp wiring kit or does one come with the SS pn2.350d
Old May 30, 2013 | 09:09 PM
UltraNutZ's Avatar
UltraNutZ
if you're staying with the stock head unit. you need 8ft of 10ga power wire, a fuse holder, and a 30A fuse. That's it.
Old May 30, 2013 | 09:10 PM
Gearheaddrew
Nice.. Thanks for the info.. So basically the Polks and any "mini" amp would be a respectable 2 speaker system..
Old May 30, 2013 | 09:13 PM
UltraNutZ's Avatar
UltraNutZ
whoa... slow your row there pal.. :-)
the polks are 2.7 ohm speakers so if you don't go the route of the SS amp, you'll need to make sure your amp can handle a 2 ohm load. Otherwise you're going to have to go a different route altogether...
the key to this is matching components for best sound quality.
Old May 30, 2013 | 09:16 PM
UltraNutZ's Avatar
UltraNutZ
another good choice of amps is the RF PBR300x2. it's stable at 2 ohms as well.
Old May 30, 2013 | 09:18 PM
Gearheaddrew
Ok.. heres the master plan.... fairing speakers and an amp this year and hopefully speaker lids next year... im not the richest person on the planet and there are a lot of other things I spend $ on besides my bike...
Such as Anheuser busch products...
All my local indys and dealers are preaching Boom! Audio and Hogtunes..
Old May 30, 2013 | 09:29 PM
UltraNutZ's Avatar
UltraNutZ
Sitting here putting away my 8th bud light I completely understand. You'll regret the BA and HT expense is all I'm saying
Old May 30, 2013 | 09:39 PM
Gearheaddrew
Does the Rockford amp come with the fancy connectors they show or is that sold Seperate? Also is the 4 channel able to run just my fronts and leave the rear channels for the hopefully future bag lids
