CD Skip...could be the handlebar bracket boltheads
https://app.box.com/s/xejsm8vl9lpccisqy4cq
The replacement bolts were a little over 2 bucks at the HD shop. I took some before and after pictures, as well as pictures of the old bolt compared to the newer short-headed fastener.
First, here is a shot of the old bolt on the left and the new one on the right:
Here is a shot of the head configuration. The old bolt has an Allen head and the new one has a Torx head:
Here is a before shot with the old bolts still installed. Sorry for the focus issue:
And here are the newer bolts installed:
When I removed the HK, it appeared that the left stock bolt (as viewed in the photo) was making a little contact with the bottom of the unit. I wasn't experiencing any problems, but figured while the radio was out anyway, this was the perfect time to change out the bolts to avoid any issues down the road. I also re-torqued the stem nut since removing the HK made it perfectly available.
NOTE: Remove and install one bolt at a time. Do not remove both front bolts at once, or you risk the possibility of unexpected handlebar movement.
Like I said, I hadn't experienced any issues, but it would have been foolish not to change-out the bolts while the radio was out...so I did.
