amps made in usa
our website software is also almost finished to allow the user to download certain programs for their J&M class G, ROKKER XT amp, and load them in while the amp is still mounted in the faring ,,,,,,
most important however is to make sure that the input gains for our amps are adjusted PROPERLY for each particular 2, 4, 6 or 8 speaker configuration ,,,,,,,,
we don't ever want to go back to the days when the installer would just crank the amp gains to maximum, just so the customer would not ask for more after the bike is back together, and then wonder why all the speakers burn down in a few short weeks ,,,,,
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
Class D is good for my application, because I care about heat and weight and the only time the radio is on is between CDs. So, I just picked up a BT-454 from a member. Hope it has enough pwr for my two 4ohm Focals and Stevie Ray Vaughn.
If this thread can stand more off-topic stuff, I've a new question. I've added a few things like auxiliary lights and the amp. Next addition is power inside my on-again-off-again tour pack for an LED light bar and charging my phone. The lights in particular came with lots of wire, w/connectors. The looong lengths of wire currently are nicely looped and zip tied inside the fairing. Is that bad? Should I keep all wire runs only as long as reasonably necessary, even spkr wires?
What's the best source for quality moisture proof insulated connectors?
TIA
Moisture proof connectors can be found at digikey.com and mouser.com.
with all due respect ,,,, you are making an incorrect statement ,,,,,,,
DISTORTION is what destroys a speaker, regardless of brand ,,,,,,,
when you guys adjust the amplifier input gains to levels that cause you to run down the highway at high distortion levels for hours on end, and then blame the speaker manufacturer when the speakers burn down ,,, that is wrong ,,,,,,
it is no different than putting a supercharger on your engine, with a boost pressure screw adjustable by the rider, and then after 2-4 beers the screw is turned all the way up, so that you are faster than the next guy, and then wonder why you have piston erosion the next morning ,,,,,,,
the J&M ROKKER XX speakers http://www.jmcorp.com/ProductDetail....=HCRK-7252-RXX ,,,, are THE MOST durable speaker ever made for the Harley Bagger audio systems, but they can still be damaged by incorrect input gain adjustments to the amplifier ,,,,,,,
now please educate yourself a little more on this subject prior to making these types of statements ,,,,,,,,
I have been doing this for 35 years ,,, and while I do not know everything, I know a little bit about this subject ,,,,,,
As an engineer I do like to keep myself educated in these matters. The assumption then is that your amplifiers are either Clipping, have bad Intermodulation Distortion, and/or Harmonic Distortion. This is caused by non-linear behavior of electronic components and power supply limitations. Of course this can be remedied with proper engineering in the design phase of the amplifiers development. Perhaps you might want to consider adding a simple 'peak limiter' at the amplifiers input too. In any event, it sounds like the amp is not folding back when driven into distortion, thus passing on square waves to the speakers and blowing them. Your amp does have a 'Fold Back' circuit designed into it doesn't it? A lot cheaper than DSP and you'll never cook a speaker or blow an amp.
Also, let's talk about speakers. Enquiring minds would like to know why certain purveyors of audio products advertise their speaker ratings in 'Max Power' rather than the more scientifically accurate Watts RMS. 'Max Power' is a nebulous statement. It is useless information unless backed with some data to show how one arrived at that number. Hence the use of the term RMS which is widely used to show the long term handling power of a speaker. Max Power states nothing as it does not show the durations and period of the peaks. It is why reputable speaker manufacturers always rate their speakers in RMS. Most manufacturers are also more than happy to advertise the audio curves of their speakers to illustrate how flat they are. That way you can see all the peaks and dips across its frequency range and decide if that's the right speaker for you. And how about speaker sensitivity? Again, that's another piece of useful information that is always advertised by leading manufacturers.
The stereo buying public would like to be able to see factual technical information in order to make sound buying decisions (pun intended.)
that all sounds good for "BOOK" theory, now put it to practical use on the Harley Baggers ,,,,,,,,
as for J&M ROKKER XX speaker specs ,,,,, max power, RMS power and sensitivity ,,,, they are all here http://www.jmcorp.com/ProductDetail....=HCRK-7252-RXX ,,,,,,,,
