I have a question about my Navigational system on the Infotainment System, every I choose Destination /Address it defaults to CANADA. I have no problem with Canada, but I live in Virginia and it sure would be nice if it would default at least to the US, if not to Virginia, US or detect where I am at and go from there.
Is there a way to change the default start location?
A puzzler? Mine currently defaults to Michigan, USA.
Question - have you set your Home location yet? If not, perhaps it uses home state & country?
If you've set Home to VA, USA & it's showing Canada as default country for Where to? perhaps the default language is set wrong? Check the interface language setting to make sure English (US) is selected in the Home - Setup - Set Language menu.
Options there include:
English (US)
English (UK)
French (CA)
etc.
These are the first things I would check. Beyond this, further thought & ideas required.
