4 speakers on a pbr300x2?
Old Dec 15, 2013 | 11:11 PM
ridedaddy's Avatar
ridedaddy
Default 4 speakers on a pbr300x2?
My uncle is wanting to run a set of boom 5.25" and his boom 5x7s off of a pbr300x2. Will this work ok? I don't think his boom speaker can handle much power so 75watts per speaker should be ok?
Old Dec 16, 2013 | 12:47 AM
GLACIERPEARL's Avatar
GLACIERPEARL
No.............the Boom speakers are 2 ohm, running them in parallel would create a 1 ohm load on the amp, and blow it up. You could run them in series to see a 4 ohm load, but not a nominal setup. He needs a 4 channel amp, that is 2 ohm stable.
Old Dec 16, 2013 | 01:50 AM
ridedaddy's Avatar
ridedaddy
Yes they would have to be run in series. Didn't realize the pbr would be 100x2 @ 4ohms. A pbr300x2 @ 4ohms it would be 100w per channel or 50 per speaker. Does this seem sufficient for the boom speakers? What are the boom speakers rated to handle? Don't seem to be able to find any specs, they must not be to proud of them. Lol
Old Dec 16, 2013 | 03:56 AM
Pioneer74's Avatar
Pioneer74
Boom speakers can handle about 40 watts a channel RMS, so running them in series is an option with the pbr300x2, but you wouldn't have any fade control between them.
Old Dec 16, 2013 | 04:53 AM
ridedaddy's Avatar
ridedaddy
Thanks pioneer
Old Dec 16, 2013 | 06:20 AM
UltraNutZ's Avatar
UltraNutZ
go easy on those gains controls.. you'll tear those boom speakers up in no time even wired in series. They can't handle much power at all.
Old Dec 17, 2013 | 05:59 AM
ridedaddy's Avatar
ridedaddy
Thanks ultra. On a more intresting note than the boom stuff I should be getting my ss hooked to my mm651 any day now👍
shimaze
Audio Systems
19
Jan 17, 2017 12:27 PM
roussfam
Audio Systems
Oct 3, 2015 09:45 AM
blazemate
Audio Systems
Sep 15, 2015 07:18 PM
bigreds1963ss
Audio Systems
Mar 24, 2015 10:04 PM
reserve
Aug 31, 2012 12:41 PM
