Hooking up amp High Level??
Old Feb 9, 2014 | 02:47 PM
jps9287's Avatar
jps9287
Default Hooking up amp High Level??
Im to the point now where I am hooking the amp up and I have a couple questions. I soldered the red black and yellow from radio harness to biketronics harness that leaves me with the four speaker wires. So do I tie in the 4 speaker wires from the head unit to the amp input harness and leave the 4 wires from the biketronics harness unhooked??
Old Feb 9, 2014 | 02:48 PM
jps9287's Avatar
jps9287
guess you should know that I have a kenwood head unit and rf pbr 300x2 amp
Old Feb 9, 2014 | 05:46 PM
futat2's Avatar
futat2
Speaker wires from head unit to cut off RCA wires to input of amp.
Output wires from amp to BT control box speaker wires. use factory speaker wire connections at speakers.
Old Feb 10, 2014 | 07:16 AM
UltraNutZ's Avatar
UltraNutZ
correct. head unit speaker outputs to the high level inputs on the amp. I would leave the stock speaker wiring alone so you can put it back later on if needed. Simply run a set of wires from amp to each speaker, set your gains, and you're done.
if your kenwood head unit has 5v RCA outputs, use those instead of high level inputs.
Old Feb 10, 2014 | 08:51 AM
jps9287's Avatar
jps9287
My particular unit puts out 4v RCA or high level
Old Feb 10, 2014 | 08:52 AM
UltraNutZ's Avatar
UltraNutZ
then stick with high level inputs.
WVFLHX
Audio Systems
31
Mar 23, 2025 07:36 PM
KSGLIDEGUY
Audio Systems
36
Mar 1, 2018 12:52 PM
racenut.pp@gmail.com
Audio Systems
Apr 4, 2017 11:07 PM
Scooby1426
Audio Systems
13
Jul 18, 2015 03:14 PM
Sire2Twins
Touring Parts
Sep 21, 2014 05:39 PM
