Rear Speaker Popping Out
Old Feb 22, 2014 | 08:36 PM
RPS1981's Avatar
RPS1981
Default Rear Speaker Popping Out
I tried this in the Touring Section, with no response... trying here.
I'm almost embarrassed to be posting such a silly question, but what is the proper installation method for rear speakers in factory speaker pods?
I replaced my rear speakers with Hogtunes last winter and at least four times I've finished a ride to find my right rear speaker on the seat or saddlebag lid hanging by the wires. The speaker, trim ring, screws, and rubber/brass inserts are all together as a unit -- the entire thing just pops out of the speaker pod.
I've replaced the little rubber/brass threaded inserts with new ones. I've tried putting the inserts in both ways, and the speaker won't stay put. There's not much detail in the service manual (why would there be? should be a no-brainer).
Old Feb 22, 2014 | 09:58 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Just use a bigger screw. Had to do that too !!
Old Feb 23, 2014 | 06:57 AM
RPS1981's Avatar
RPS1981
Thanks, Glacierpearl. Did you also use a different anchor to screw the bigger screw into? On my bike, the machine screws thread into a rubber bushing with a brass threaded insert. So a bigger diameter screw would require that it have something different to screw into.
Old Feb 23, 2014 | 07:40 AM
GLACIERPEARL
I drilled new , bigger holes, and just used wood/machine screws.....no problems since.
Old Feb 23, 2014 | 07:41 AM
UltraNutZ's Avatar
UltraNutZ
don't use the rubber inserts. rotate your speaker to where the holes do not line up with the rubber inserts. drill a pilot hole (smaller than screw you're using) and then run your screw in. If you continue to have issues, you can go down to any auto sound shop and pick up a few of these speed clips.
https://www.hdforums.com/forum/11160547-post1.html
Old Feb 23, 2014 | 08:52 AM
RPS1981's Avatar
RPS1981
Beautiful. Thanks, guys.
s76helipilot
Audio Systems
Feb 5, 2016 11:19 AM
RPS1981
Feb 17, 2014 10:12 PM
rrcrum
Dec 2, 2012 05:27 PM
greg3131
Aug 29, 2010 05:53 PM
BAGGERNATE
Jul 17, 2010 03:21 PM
