RCA amp input issues
Old Feb 26, 2014 | 11:16 AM
chevele72's Avatar
chevele72
Default RCA amp input issues
Just wanted to throw this out there in case someone else wants to use the RCA's or has an issue.
I have an older Sony HU and a ARC 125.2 bridged to 4 speakers in upper and lower fairings. I prefer using the RCA inputs/outputs for the cleaner sound. I've been having issues with the left channel on the amp going in and out. I found that the plug on the amp was loose inside the amp from the plug/cable vibrating, and I used the 90° plug cables for the reason of not having extra hanging out and stressing the plug. I fixed this plug twice, tightening the contacts up and a solder joint once.
Well it came to a head the other day (3rd time) and dug out the pigtail to connect the regular output of the radio to the wired input on the amp. Everything is fine now, but I can tell the difference in the sound.
This setup on the bike is at least 4 or so years old and still sounds good, just another thing to think about for the next setup!
Old Feb 27, 2014 | 08:32 AM
UltraNutZ's Avatar
UltraNutZ
Have you conferred with ARC about the RCA plug issue?
Old Feb 27, 2014 | 10:45 PM
acchd's Avatar
acchd
I had similiar symptoms recently on one channel. Fortunately it was a bad RCA cable after 4 yrs. Picked up some 1.6ft StreetWires zero noise RCA cables on eBay and back in business.
Tn.Heritage
Audio Systems
Jun 28, 2015 09:00 PM
ridemyglide
2014-2024 Touring Models
Apr 7, 2015 10:13 AM
wrenchguy24
Dec 25, 2011 10:36 AM
hougz79
Sep 7, 2011 04:00 PM
jgreg65
Feb 16, 2010 10:23 AM
