Help Using DMM to set gains
Old Apr 12, 2014 | 11:28 PM
ep120794's Avatar
ep120794
Default Help Using DMM to set gains
Where do I put the probes from the DMM on this picture? Do I also need to unplug the rca speaker inputs from the amp?
Old Apr 13, 2014 | 12:05 AM
acchd's Avatar
acchd
Measure at speaker outputs at amp and disconnect your speakers.
Old Apr 13, 2014 | 12:15 AM
ep120794's Avatar
ep120794
So is that the bottom picture where it says R CH (+ and -) and L CH (+ and -)? That 4 different holes. Where do the probes go?
Old Apr 13, 2014 | 12:58 AM
acchd's Avatar
acchd
Yep that's right.
Old Apr 13, 2014 | 09:31 AM
ep120794's Avatar
ep120794
Do I just choose either the L Ch or R channel and the the red probe in the positive and the black probe in the negative after pulling the speaker wire out of those posts and after disconnect the speaker inputs?
Old Apr 13, 2014 | 09:44 AM
AAWAV's Avatar
AAWAV
correct - opposite rd probe on neg and black on pos will work too... you are measuring AC, hence there is no positive or negative signal (actually there is but it is both!). you are measuring a "sinus wave".
Budda109
Audio Systems
45
Sep 3, 2015 08:03 PM
bhibbert80
Audio Systems
Apr 29, 2014 12:08 PM
2006streetgliden
Jun 16, 2012 10:05 AM
nivensid
Jun 4, 2012 03:41 PM
trnewman
May 29, 2012 01:01 PM
