audio
Old May 1, 2014 | 05:58 PM
FOCI's Avatar
FOCI
Smile audio
i have a 2006 flhxi and recently i have been notice that when i turn on the radio while riding or any time the volume seems to fluctuate by it is self is there any thought what the problem is? How can i fix it?
Old May 1, 2014 | 06:47 PM
Pioneer74's Avatar
Pioneer74
Are you using the AVC feature?
Old May 2, 2014 | 07:59 AM
FOCI's Avatar
FOCI
yes i am using avc but i will try shutting it off .
Old May 2, 2014 | 09:00 AM
UltraNutZ's Avatar
UltraNutZ
also is the head unit stock or aftermarket and if aftermarket which handlebar control module?
Old May 3, 2014 | 01:41 PM
FOCI's Avatar
FOCI
it is stock system and it seems to be okay since i shut off the avc
Old May 3, 2014 | 02:03 PM
Pioneer74's Avatar
Pioneer74
Probably a dirty speed sensor.
Old May 3, 2014 | 06:27 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Better than a Dirty Sanchez !!
Old May 5, 2014 | 12:07 AM
AmericanHB's Avatar
AmericanHB
Former Sponsor
Ha!!!
Old Aug 31, 2014 | 04:09 PM
FOCI's Avatar
FOCI
Unhappy updated problem
well here is the problem while i am riding with the radio on it will loose audio yet the radio will show that the volume is up and the radio will be lit up and also show the radio station that is supposedly playing yet no sound out of speakers so i turn it off and a little while later i will turn it back on and i will have sound again but then a while the audio will go out again the system is stock with avc on and off does not make a difference It is a 2006 streetglide please assist someone says a dirty speed sensor . should i think it might be in the radio itself in which case is it worth getting repaired
Old Aug 31, 2014 | 04:54 PM
Pioneer74's Avatar
Pioneer74
Sounds like you are describing something fairly common with the Harman Kardon head unit. It probably has a broken circuit board due to vibration and some bolts that are too big. It can be repaired by taking it out and sending it to Iron Cross.
http://www.ironcrossaudio.com/
