confused
Old Jul 13, 2014 | 08:53 PM
08 geezer glide's Avatar
08 geezer glide
Default confused
I just installed a pbr 300 x 2 with a set of m262 and a set of Memphis tweeters. Both witch are 4 Ohms. I wired in parallel and tested load at amp.when I first put meter on it shows 2 ohms but then goes to 3.6. Is this because of the caps in the cross overs? If I take another 2 way 4 ohm speaker and wire it to the m262 it shows 2 ohms and doesn't change. I plan on running another set of the m262 in the lower fairings. Just running this temporary.
cshocker
Apr 20, 2017 09:10 AM
billablehours
Audio Systems
Jan 31, 2017 10:29 AM
Djeazie
May 27, 2016 10:44 PM
tdgriff
Audio Systems
14
Aug 31, 2014 03:45 PM
slugo
Oct 14, 2006 01:26 PM
