Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
carb issues
Old May 28, 2015 | 11:55 PM
pacman552sd's Avatar
pacman552sd
Stage II
Default carb issues
Hi everyone . I'm here with a few questions. I just bought a 89 sportster 1200 with a cv carb . The previous owner took the carb apart to clean it and ever since then the bike won't run right. The bike starts and idles fine . If you snap the throttle open then closed it revs up fine . But if you snap it open and hold it or if you just slowly open it the bike sputters and dies . After reading up on this carb and having a little experience with carbs I have a few ideas what to do but I would like to know if you guys know of any other causes of problems like this. I already ordered a gasket kit for the carb and plan of checking for intake leaks before i tear the carb off.
So far my ideas of the issue are
1. Plugged main or needle jet
2. Damaged needle
3. Improperly installed collar on the needle
4. Missadjusted float
I also have a few other more far fetched ideas if those don't work. But do you guys have any other ideas?
Old May 29, 2015 | 02:33 AM
pacman552sd
Stage II
did a little investigating, removed the air filiter and gave the carb a good look over. the collar that the needle rides into seems to be farther into the body of the carb then what i have seen in pictures i have found online. do you guys think that the collar is installed upside down
Old May 29, 2015 | 02:55 AM
Ron750's Avatar
Ron750
Can't help, but here is a bump.
Old May 29, 2015 | 12:39 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The long end goes into the carb throat.
Old May 31, 2015 | 09:37 AM
Yankee Dog's Avatar
Yankee Dog
If your talking about the needle jet, then yes, they are often reinstalled wrong. Could it be an aftermarket needle that uses clips and is installed way to far down?
You really need to take the carb apart. If you suspect a clogged main, then the pilot jet will definitely be clogged. Get a can or two of carb cleaner, a parts diagram or even a how to instructions and take it apart and give everything a good once over.
Here is a great source for parts and info:
http://www.cv-performance.com/carbur...eatured&page=2
Good luck. YD
Old May 31, 2015 | 09:48 AM
Dan89FLSTC's Avatar
Dan89FLSTC
This is the classic symptom of the needle jet installed upside down.
Don`t ask me how I know...
Old Jun 3, 2015 | 10:39 PM
Ed Ramberger's Avatar
Ed Ramberger
+1 on the needle jet (tube) is most likely upside down. Unfortunately I learned that lesson 20 years ago and never forgot it.
MBRADE
Carburetor Related
May 12, 2013 08:47 AM
bryon857
Ironhead
Feb 21, 2008 06:56 PM
Paulution
Jul 28, 2007 05:28 PM
FatBoyinNJ
Exhaust System Topics
Sep 7, 2006 07:26 PM
Beeracuda
13
Dec 27, 2005 03:16 PM
