Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Carb ?
Old Nov 23, 2020 | 02:27 AM
fireman64's Avatar
fireman64
Default Carb ?
Bought a '98 softail late this summer, and it's a cold blooded thing.. The colder it gets the harder it starts.
And til it's really up to temp it will backfire on decal.
Stock carb , but getting gas.. so new plug and carb kit in order ?
Thanks
Old Nov 23, 2020 | 03:49 AM
eighteight's Avatar
eighteight
Cold blooded after starting is a by product of the stock carb jetting, need to fatten it up
Stock was #42 pilot and #170 main ? You`ll need to go in and check what you have BEFORE ordering jets from CV PERFORMANCE
I`d try 45 & 180
Hard to start cold : depending on temps, you might need to wick the throttle twice before hitting starter. The accelerator pump ( assuming it`s working) will throw raw fuel down the intake.
You are aware of the "enrichner / choke " **** right ? ( no offense meant, but some have never had a carb bike)
Check all exhaust fittings / bolts for tightness to minimize popping
EDIT your location is "m" , that could be Maine or Mississippi, big difference in "cold" LOL
Old Nov 23, 2020 | 05:38 AM
fireman64's Avatar
fireman64
I do know the choke and live in Minnesota so we're in the 30s now.. Turns over for ever.. Took the air cover of and and it appears to be getting fuel..I don't have a heated shop.
But plan on tinkering with it this winter. I'm set to get new plugs, don't know how old these are.
Old Nov 23, 2020 | 05:46 AM
Jackie Paper's Avatar
Jackie Paper
At 30 degrees, I wouldn't worry about how cold-blooded the Harley was. My concern would be my butt.
Come summer, you will change your mind...?
If the carbs right, it will run however even in cold weather. From what you described at decel, could be too much fuel. But if it's got open modified exhaust, they tend to do that if you snap back the throttle too fast.
Old Nov 23, 2020 | 05:59 AM
RANGER73's Avatar
RANGER73
I stopped my decel popping by increasing my low idle just a little.
BobbyH83
Nov 26, 2017 08:31 AM
Vmann
EVO
17
May 29, 2017 06:00 PM
falconbrother
EVO
16
Jan 28, 2014 08:17 AM
the blob
EVO
Nov 21, 2010 11:02 AM
Garett
Exhaust System Topics
Feb 1, 2009 03:47 AM
