Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
Mikuni carb hard to start when bikes cold!
Old Oct 22, 2023 | 12:10 PM
91jfk's Avatar
91jfk
6th Gear
Default Mikuni carb hard to start when bikes cold!
So I’ve got a twin cam 88 modified nicely and has always surprised my mates with how instant my start ups were after doing upgrades which are as follows; Vance and hinge big radius pipes, rocket 514c cams, mikuni hsr42 with mikuni manifold and enrichner, fueling cam plate and oil pump, se lifters and s&s adjustable pushrods. I originally have the mikuni aircleaner set up but kept splitting the rubber backing plate they come with so upgrade to an arleness velocity 65 degree aircleaner kit which at first was great! But in the last few weeks when I go to start the bike for the first time that day I pull the enrichner out and wind it over maybe 4-5 times before it will start, and when it starts it takes a few moments to raise the rpms and by that time pushed the **** back in and am using my throttle to keep the revvs steady for about 30 seconds then I’m good to go! Other than that bike starts as soon as I push that button! Should I suspect enrichner problem or the 22 year old fuel tap maybe?
Old Oct 22, 2023 | 07:52 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Might wanna check the enrichener cable and piston to see if it's sticking. OEM vacuum petcocks are known to have the old vacuum lines crack as they age. Sucking in more air and less vacuum to open the diaphragm. IF that's the case, get a Pingle petcock.
Old Oct 22, 2023 | 08:19 PM
TwiZted Biker's Avatar
TwiZted Biker
Agree with Trash above, got an air or vacuum leak developing, cold natured at start up and stumbling till warn suddenly is an early sign.
Old Oct 23, 2023 | 08:05 AM
Architect's Avatar
Architect
Give the intake manifold a look, something changed and needs to be addressed, good luck.
Gustave Verbraak
Twin Cam Motors
Aug 2, 2021 05:10 AM
Khali20830
EVO
47
Apr 6, 2021 08:19 PM
cypressd
Feb 17, 2021 09:36 AM
jherzer25
EVO
17
Oct 28, 2015 06:02 AM
72rigid
Ironhead
Sep 29, 2006 10:28 PM
