Carburetor Related Find discussions on carburetor related goodies here. Swap and trades? Rebuild information and tuning for the pre EFI systems.
CV carb air fuel mixture adjustment
Old Sep 8, 2025 | 09:26 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Originally Posted by Mattbastard
Back in my CV40 days, I've tuned a bunch of them. From an 883 or 1200 Sportster, Evo, or Twinkie, here's my rules of thumb:
Idle mixture screw 3 turns out
45 Pilot
#4 brass washer under needle
Main based on displacement. I recall a 170 was a good fit in a 1200cc warmed over Sporty, so I'd toss a 180 main in your CV and run it.
BTW, doing plug chops and checking the ceramic around the electrode was a good way to see a tune, but with today's unleaded fuels and the hot plugs Harleys tend to run, it's not too reliable anymore. That soot around the threaded part is totally normal because it's much colder than the electrode is.
Matt makes a good point about washers under the needle. I got started with that as a kid on jap bikes. When you open up the intake and exhaust those raised needles can get back that little dip in the midrange. On my 03 Dyna I have V&H Short Shots with the free flowing baffles. I actually had to go with three washers because of how anemic the midrange was. Smartest thing to do would be to get a better set of pipes, but I love how compact the short shots are. It really makes it easy to work on the bike without a large exhaust system. Nothing hanging out to ding and scratch either.
Old Sep 8, 2025 | 09:40 AM
Bubba Zanetti's Avatar
Bubba Zanetti
I'm running Straight Shots, not Short Shots.
Old Sep 8, 2025 | 03:52 PM
Mattbastard's Avatar
Mattbastard
No baffling? Put some lollipops in the last couple inches of the exhaust, you'll get your midrange back.
Old Sep 8, 2025 | 06:08 PM
Bubba Zanetti
They’re called Straight Shots but they’re not straight pipes. They’re made to look like straight pipes.
There are baffles in them.
Old Sep 8, 2025 | 06:29 PM
Bubba Zanetti
Originally Posted by John Harper
If you're turning the IMS clockwise, you are making it leaner. A 42 pilot and 165 seem lean for a 1340, as I have bigger jets in my 1250.
"I turned it all the way in clockwise and nothing happened." That would indicate to me that the throttle plate is not closed enough at idle, and you're running on the transfer ports. Back your idle speed down and try fiddling with the idle mix screw again. I was getting some decel popping and kept richening the IMS which did not help. Then, I backed the idle speed down, readjusted the IMS (leaner), and voila, no more decel popping. I was obviously running a bit on the transfer ports.
I might be worth pulling your pilot jet and idle mix screw, blasting out the passages and ports, just to make sure there's no boogers in the passages. I have been adding some Seafoam to each tank of gas, which keeps the jets clear. I ran without it for a while an could tell the pilot jet was getting clogged as it started a bit of decel rumbling/popping, which cleared up immediately after a dose of Seafoam. Actually, I use WM Motor Treatment, which is probably the same a Seafoam for considerably less. All I know is that it keeps my carb happy and supposedly stabilizes the fuel if I don't get a ride in at least every couple weeks.
I'd say 2.5 turns out is a good place to start, but set that idle speed low and then fiddle with the IMS. You can always set the idle speed after you've found the sweet spot with the IMS, but you need those transfer ports taken out of the equation.
John
I backed the idle RPM down to around 700 then set the mix screw to 2 1/2 turns which seems to be the sweet spot.
Bumped the idle back up to around 1000 and took a ride. It seems to be better but I only got to run about 10-15 miles. I’ll know better once I get a few miles on the old girl.
Old Sep 8, 2025 | 07:02 PM
John Harper's Avatar
John Harper
Nice work, grasshopper!
John
Old Sep 9, 2025 | 05:16 AM
Bubba Zanetti
John
Thank you Master Po. 😉
Old Sep 12, 2025 | 12:27 PM
marcodarq's Avatar
marcodarq
45 slow jet
180 main jet
IMS 1.5-2.0
you would have to experiment or have it on the dyno to really know the cruise ligh throttle application, but i have done it befoe
m
s-glide76
Carburetor Related
22
Jul 11, 2025 02:00 PM
Rt13MFer
Carburetor Related
Jun 25, 2021 08:29 AM
lonerider1960
May 21, 2020 01:29 PM
blueEglide
Sep 19, 2008 07:04 PM
timberwolfz28
Aug 3, 2008 06:46 PM
