Classic All 'historic' bikes.
I got a question about el and fl
Old Feb 1, 2016 | 09:42 AM
ryanneal7223's Avatar
ryanneal7223
Default I got a question about el and fl
I'm just wondering for example a 51 el panhead would look identical to a 51 fl panhead... So I'm just wondering if there's and appearance differences between el and fl
Old Feb 1, 2016 | 09:44 AM
perki48's Avatar
perki48
The serial #'s
Old Feb 1, 2016 | 10:10 AM
ryanneal7223
I knew that
Old Feb 1, 2016 | 10:19 AM
perki48's Avatar
perki48
I knew that
I was just trying to say that is the ONLY way I know of to visually tell the difference. I believe identical otherwise except for displacement.
Old Feb 1, 2016 | 11:10 AM
ryanneal7223
I was mainly wondering if the cylinders were longer for the larger stroke
Old Feb 1, 2016 | 11:23 AM
sqdealgeorge's Avatar
sqdealgeorge
Default EL vs FL
The EL's (if orig ) have a shorter stroke than the FL's Yes the cylinders for an EL are shorter You can use FL cylinders on a stock stroke EL only the pistons(stock) do not quite make it to the top of the FL cylinders making for low/low compression My knuck came with a 61 CI bottom end( EL) 74 CI (FL) cylinders ran good and I could kick start it with my arm ! (early 70's ) I'm paying for that mistake now I stroked that knuck in the 90's S&S 4 1/4 wheels What a power difference that made Sold the knuck in 2015 SAD DAY oh well
Old Feb 1, 2016 | 04:25 PM
panz4ever's Avatar
panz4ever
Basically comes down to engine displacement, but as mentioned there are some internal differences as well as some external (shorter cylinders, different sized intake manifolds)....but unless you measure it is difficult to tell. Biggest giveaway is the VIN#.
54Pan
Panhead
Aug 30, 2017 11:43 PM
ryanneal7223
Mar 23, 2016 09:25 PM
DerekShiekhi
Nov 3, 2015 03:23 PM
harpwrench
Motorcycles For Sale
May 4, 2012 07:25 PM
