hi . I'm hoping some one can help me find a headlight nacelle for my 80 roadglide , I'm wanting to take the fairing off and do alittle customizing , i need the nacelle that forms around the dash , it's that oblong dash ,having trouble finding one , also interested in windshield ,light bar , if anyone could help that would be great Thanks Don
You can find most of the headlight parts for a FLT headlight conversion on ebay. You will
need an old style auto headlight connector - a junkyard is a good source. There is a connector
block between the harness and the fairing and you will have to splice into the harness to feed
the high, low and negative to the junkyard connector. I did not use turn signals and light bar
but you would have to splice into those wires as well.
You can find the nacelle in most of the catalogs. There are 2 models - with or without the
hole for the cables. Most of them are chrome plated plastic. I did see one of aluminum but
do not know the manufacturer. I have the inner headlight bucket available.
i have a 87 flt i want to remove the fairing and install a headlight nacelle, the kit in vtwin parts book says it will fit 80-86, does anyone know if they also fit other years? also will a flhs nacelle work? thanks, tom
I'm trying to convert my 1980 FLT from that ugly plastic speedo/tach dash to an old school nacelle.can it be done? The upper tree width,(where the nacell bolts to on each side),is 13".All the chrome and aluminium nacelles measure 12".aRE All other forks 1 " narrower than the FLT?
