Classic All 'historic' bikes.
Removing Rocker Box
Old Jul 16, 2005 | 02:52 AM
imboden's Avatar
imboden
Default Removing Rocker Box
This 72' super glide I keep talkin about, well I'd like to take off the rocker boxes and get them cleaned up too.
I'm curious....since I don't know anything about motors (kinda) is it safe to take these off? I mean other than removing the obvious nuts/bolts, will I mess anything up?
I just need to get them off to give them a good scrub and polish.
thanks-
pat
Old Jul 16, 2005 | 10:18 AM
71 shovelhead's Avatar
71 shovelhead
Default RE: Removing Rocker Box
If this is a stock frame you're gonna have to pull the heads or pull the engine as there isn't enough room to lift the rocker boxes over the valve springs and studs
Old Jul 16, 2005 | 07:08 PM
imboden's Avatar
imboden
damn, I didn't even consider that. I just went out and looked at the nuts and bolts portion. yeah it's a stock frame. wow, more to this than I thought. not so sure it's worth it now, I might just put my time into the small cracks with steel wool and polish.
Old Jul 23, 2005 | 09:42 PM
jrp's Avatar
jrp
I was gonna pull my rocker boxes until I heard that I'd have to pull the heads! My chrome RBs are flaking so I just wire brushed them and polished the exposed aluminum with a dremel. I'll wait for the overhaul time and do everthing then.
89FLHTC
EVO
13
May 19, 2016 06:04 PM
CrazyBoom
Jan 17, 2012 05:01 AM
MikeSki
Feb 15, 2011 06:36 PM
sailfish
Shovelhead
Sep 21, 2010 08:16 PM
ink.slinger
Shovelhead
May 8, 2008 04:18 PM
