Unknown component
Old Aug 18, 2022 | 07:06 PM
ARNAV's Avatar
ARNAV
Default Unknown component
Hello, last week rode my Softail Evo Ultima 127 and suddenly had a backfire and saw smoke coming from underneath in the starter area. I remove this component, I think but not sure that the smoke came from it, and I want to replace it.. but what is it?..
Old Aug 18, 2022 | 08:24 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
That is the main circuit breaker.
Disconnect the battery before you mess with it.
Old Aug 18, 2022 | 08:40 PM
TwiZted Biker's Avatar
TwiZted Biker
Did you smell electrical burning with the smoke or something else ? Those circuit breakers do go bad but they usually don't do the mushroom cloud thing. You'll hear a pop and nothing works anymore.
Old Aug 18, 2022 | 08:44 PM
ARNAV's Avatar
ARNAV
Thanks!
for the new one that I will buy - do you know which terminal should I connect to which wire? I see that terminals are different, one is brass and one is steel.
Main circuit breaker
Old Aug 18, 2022 | 08:49 PM
ARNAV's Avatar
ARNAV
there was some noticeable white smoke, a misfire and then engine stopped. I will start with replacing the breaker. It’s strange that I don’t have any fuses anywhere, just the ignition controller that looks fine, not burned, and the main breaker.
Old Aug 18, 2022 | 08:54 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Copper color stud is power in to breaker.
Silver color stud is power out of breaker.
Old Aug 18, 2022 | 09:58 PM
ARNAV's Avatar
ARNAV
Thank you!
Old Aug 18, 2022 | 10:01 PM
ARNAV's Avatar
ARNAV
I will investigate more, will remove the controller and unused wires, and will add a main fuse... will take some pictures and will ask you. Thanks again!
Old Aug 19, 2022 | 03:55 PM
Lunchboxx's Avatar
Lunchboxx
Looks Like a circuit Breaker to me
Old Aug 28, 2022 | 07:31 PM
ARNAV's Avatar
ARNAV
Default Problem continues
Connected the new main circuit breaker, connected the battery and pushed the starter.
some noise came from the starter for only 3 seconds, then the main breaker poped.
do you think the starter is burned? Should I pull it out?
