part numbers
Old Nov 27, 2005 | 11:33 AM
72SHOVEL's Avatar
72SHOVEL
Default part numbers
does anyone know of a web site that you can just enter a part number to and find what it is (year, modle,size) I am rebuilding an old ironhead that I got years ago. Found the motor that I had was a basket case, I knew the guy that put the thing together, and I don't think he had the correct parts. Thye block was (4A12206H0) thinking that it was a 70 (900) when I pulled it apart I found a mess. The jugs wewe scored, pistons were wiped out on the back side only. Further inspection of the cases found that the motor had been broken and rewelded more that once. I whent and bought a newer block (3A30508H2) thinking it is a 72 (1000). I grabed some heads from a friend (16682-71,16684-71). Looking to see if I can use thies heads with this block and what jugs to use.
Old Nov 27, 2005 | 12:55 PM
pococj's Avatar
pococj
Default RE: part numbers
I think the '72 models, first year for the 61 inch motor, had heads different than earlier and possibly later models. Heres a link to an excellent Sporty joint where you might get some better help than my tired ol' brain:
http://www.sportster.org/home.html
Old Nov 27, 2005 | 02:13 PM
72SHOVEL's Avatar
72SHOVEL
HEY THANKS, this has been a real pain trying to get info for this project. I have built a frame for the motor and was quite pissed when I found the motor was a bust. with this new block i hope to finally get this chopper together. Hey I have hered some have put shovel big twin jugs on sport blocks. Is this possible? if true can I through 80" jugs on the pig with out breaking the bank?
Old Nov 27, 2005 | 03:37 PM
pococj's Avatar
pococj
Yes, Shovel top ends have been adapted to Sporty bottoms. They're known as Shovesters. Lots of machining, lots of bucks.
Old Nov 27, 2005 | 08:09 PM
72SHOVEL's Avatar
72SHOVEL
I think I'll just stick with the ironhead upper end. thanks for the heads up.
cruzmisl
Sep 24, 2023 09:28 AM
weldingrust
Milwaukee Eight (M8)
Dec 11, 2016 01:03 AM
KingLBC
Exhaust System Topics
Dec 10, 2008 11:12 PM
softailtom98
Custom Models
Jun 2, 2007 10:16 AM
coolharley
Shovelhead
13
Nov 9, 2006 11:00 PM
