Wiring Problems on EVO custom
Old Jan 7, 2008 | 11:59 AM
rwwintx's Avatar
rwwintx
Stage III
Default Wiring Problems on EVO custom
Has any one wired up the coils on a custom evo setup. Anyone that did could be of some help andwould be appreciated. It has a EVO engine with three wires coming out of the bottom right side of the engine. I am wiring up 2 Donnie Smith type coils in the v pattern on the left side of the engine. My wire harness is a Ultima Wire harness. The wire harness has the positive coil connection. Now my question I also have a factory computer box for the EVO engine with about 9 wires on it. Do I need to hook it up and go with the pink to the coil - and use the computer box positive or do i just wire one of the wires coming out of the engine directly to the - terminal of the coil. and let the ultima box do everything thanks this really has me stumped
Old Jan 8, 2008 | 06:18 PM
pococj's Avatar
pococj
Default RE: Wiring Problems on EVO custom
Do you not have a wiring diagram? Many years of Evo motors, and many different diagrams.
Old Jan 10, 2008 | 01:52 PM
sqdealgeorge's Avatar
sqdealgeorge
Pink does come off the coil the terminal opposite the hot side or the white wire side Is this 9 wire box a stock harley ign mode? does it have a 7 or8 prong plug on the end? Do you want to single firenthe coils or std dual fire?
Old Jan 20, 2008 | 09:14 PM
rwwintx's Avatar
rwwintx
Stage III
Sorry to take so long to get back with you but the way i work i get on the wiring very little.
I have a wiring diagram but i am wiring an untima wire harness to stock harley module to a set of dyna coils twi single tower ones and i can't seem to find a diagram that shows these three parts.
the module is a stock harley with a 8 prong plug with one of the prongs capped of so only 7 wires exit the connector.
here's what i have done so far white with black stripe from ultima harness {12 volts ignition} to the + side of both of the coils
pink from module to - side of the coils
white with black stripe from module to the + side of the coil
the rest of the wires hooked from module to either timing module or the voes switch per factory colors.
I get spark with the plugs out of the bike laying on the engine. not blue spark but almost more of a yellow spark put the plugs back in the engine and prime with it a little starting fluidnot even a bang.
any ideas. thanks again rwwintx
Old Jan 20, 2008 | 09:19 PM
rwwintx's Avatar
rwwintx
Stage III
geronimo73
EVO
Aug 13, 2020 02:33 PM
joker77535
Jul 5, 2013 11:27 AM
jsbridgew
EVO
Mar 28, 2011 08:05 PM
rbrapp1
Panhead
Oct 17, 2010 12:13 AM
gabarnes28
Oct 8, 2010 03:46 PM
