Replacing head gasket on S&S
Old Aug 7, 2008 | 06:03 AM
mulch63's Avatar
mulch63
Default Replacing head gasket on S&S
Hey what could cause head gasket to leak on a low mile S&S 113 CI ? Over heat? Do the heads usually need re-torque? Just wodering if I need to be suspect with a motor that needs gaskets replaced.
jim
Old Aug 7, 2008 | 06:57 AM
traveler's Avatar
traveler
Several things can cause this.
Too much oil pressure tends to blow out gaskets. Since there is an overflow system on the motor, that would have to NOT be working. Another cause is that the cylinder and heads "got loose", and the studs needs to be tightened. Lastly, once the gasket has been tightened "cinched down", if for any reason, the head is taken off and the pressure is removed from the gasket.....not changing it out and jsut re-tightening it down later can cause a leak. S&S makes GREAT stuff, I am a big proponenet of them, which is why I run their gear driven cams and gears in my twinkie. Keep in mind that not all S&S motors are built at S&S....some shops buy them unassembled and put them together, so you could be looking at a situation where the guy that built it took a shortcut, or jsut didn't know what he was doing.
~Joe
Old Aug 7, 2008 | 07:32 AM
mulch63's Avatar
mulch63
~Joe
It is in a Swift Chopper which is a good quality bike from what I 've read.
Old Aug 7, 2008 | 05:50 PM
traveler's Avatar
traveler
Sounds like you pretty much sold on the Swift bikes.
IMHO....Chica make the nicest chops out there, but I can understand going with Swift as it's ALOT cheaper cost wise over a Chica bike. I was up at Sturgis last Saturday, and if you ever get to look over a Chica bike up close, is obvious that the others are of lower quality with the exception of Ness, in my opinion.
~Joe
Old Aug 7, 2008 | 10:28 PM
Rastus's Avatar
Rastus
~Joe
Poor analogy here as in "not apples to apples". A Swift bike is a production bike and Chica's are one off customs. Ness bikes aren't bad, but he has a difficult time getting away from the 70's era styling as far as I'm concerned.
Old Aug 8, 2008 | 06:23 AM
traveler's Avatar
traveler
hmmm....I guess I'm not a big fan of production choppers.
31choptop
Panhead
Nov 4, 2013 09:39 PM
natural gasser
Exhaust System Topics
Feb 17, 2013 12:41 PM
cbaker1@farmersagent.com
11
Aug 31, 2010 08:39 AM
straydog13
Ironhead
Aug 19, 2008 09:44 AM
jakazz
Jul 2, 2007 10:05 AM
