primary leaks
Old Aug 4, 2005 | 04:13 PM
crazyhorse's Avatar
crazyhorse
Stage III
Default primary leaks
Hello and thank you for joining me. I have this custom chopper with a 113 TP motor with a outer BDL primary. For some reason ever since I owned this bike the outer primary leaks on the motor side of the house. I have change out many seals and still leaking. It seems the shops cannot get this right and I just need a little advise.
Thank You
Old Aug 4, 2005 | 07:42 PM
Scout's Avatar
Scout
Default RE: primary leaks
Did you put sealant on the bolt threads holding the primary case to the block? They will leak.
Old Aug 16, 2005 | 06:18 PM
HDWRENCH's Avatar
HDWRENCH
ok you have a 113 tp and a bdl outer primary. So you are running a wet clutch with a custom primary cover correct?? Many times you get flex with a evo set up when using a stock inner, this can cause leaks. Can you pin point the leak??
Here is a little trick for fidning leaks that spread. Clean it with soap and water removing all oil. Then get your self a can of womens spray deorderant with baby powder in it. Spray the entire area with it it will be covered in the powder take it for a short ride and the leak will be very obvious. Let me know what you come up with.
jason crago
Aug 24, 2013 06:45 PM
Ultrascott
Aug 3, 2012 04:40 AM
my dixie wreck
Jun 28, 2012 12:32 PM
motox285
Aug 14, 2010 05:22 PM
motox285
Jul 1, 2010 10:24 PM
