Remove decal
Old Aug 27, 2021 | 04:22 PM
rkted's Avatar
rkted
Default Remove decal
Greetings,
I am trying to remove the decal from my air cleaner cover. It appears to be a shiny metal material. I have tried to peel it off, acetone, wd-40 and patience, which I have exhausted. Acetone only removed the lettrs on the decal. Even tried a hair dryer. Actually, the hair dryer doesnt get it as hot as normal running conditions makes the cover extra hot. I can only peel off small bits and pieces. At that rate, I could be all day.
Any suggestions would be appreciated.
Ted
Old Aug 27, 2021 | 05:02 PM
eaglefan1's Avatar
eaglefan1
Got a picture?
Old Aug 27, 2021 | 05:06 PM
KW HD's Avatar
KW HD
Goo Off, soak a rag and let it set on the decal for a while.
Old Aug 27, 2021 | 05:13 PM
strych9's Avatar
strych9
3M Adhesive Remover. I have used it for the exact task you are attempting, and many others.
Amazon Amazon
Old Aug 28, 2021 | 09:32 AM
rkted's Avatar
rkted
As you can see it is a foil type material.
Old Aug 28, 2021 | 09:45 AM
470004's Avatar
470004
I had luck using kerosene.
Old Aug 28, 2021 | 11:15 AM
eaglefan1's Avatar
eaglefan1
I took mine off with a heat gun and a plastic razor blade.
The plastic razor blade work great on things like this. Goo gone or the 3M stuff will work, plastic razor blade makes it quick and easy
Old Aug 28, 2021 | 02:05 PM
rkted's Avatar
rkted
Mystery solved.
Because of the foil type material used in the decal, conventional products just wont cut it. So I purchased some non-marring razor blades, made by Titan. Kinda of a plastic material. Took a little work, like 20 minutes, and then clen up with Goo-Gone. It didn't hurt the chrome at all. Looks nice.
Thanks everyone for all your suggestions.
Ride safe.
Ted
Old Aug 28, 2021 | 02:06 PM
rkted's Avatar
rkted
Exactly what I did.
commander112
May 5, 2018 04:17 AM
BiggMike
Nov 5, 2009 12:10 PM
albngore
Dec 29, 2008 08:21 PM
snuffer
May 19, 2008 09:50 AM
jesserocket01
May 2, 2007 12:23 PM
