cloudy paint
Old Mar 2, 2023 | 05:53 PM
briankm98's Avatar
briankm98
Default cloudy paint
I have place right beside fuel gauge on my 2007 Fatboy that is cloudy. Any suggestions on how to get it to be clear? bike is black
Old Mar 2, 2023 | 07:52 PM
Black Ultra's Avatar
Black Ultra
rubbing compound, then polishing compound, then your favorite wax.
Old Mar 3, 2023 | 02:38 PM
Gizmo83's Avatar
Gizmo83
It would help to see some pictures, but I would start with something pretty mild like a cleaner wax and see if that clears it up at all. If not, step up the aggressiveness by starting with a hand polish then try a compound. For something available locally, you could try Meguiar's Ultimate Polish and Ultimate Compound if the cleaner wax doesn't help. Make sure it's a cleaner wax, not a pure wax. Cleaner waxes have, well, cleaners and mild polish built in.
Old Mar 4, 2023 | 05:19 AM
Kenny94945's Avatar
Kenny94945
Cloudy, only buy the gauge.
Could be surface scratches caused by rags and cleaning.
Could be scratching from the gauge trim moving around the surface.
If so, as stated above, start with a cleaner wax, then a mild polish, and last a compound.
(Yes, Meguires are fine products)
If the compound is the cure, then reverse the procedure, compound followed with polish, then cleaner wax.
If repairing by hand, light pressure and a foam applicator.
Me, I would go further and remove the gauge to access the entire surface.
PS a machine polisher could be required for a "perfect" repair.
If not scratches, I am unsure what caused the clouding, except to say a chemical reaction with the clear coat or perhaps a UV or sun fade.
Good luck.
GOGOBECK
Powdercoat & Paint
Feb 5, 2021 05:14 PM
Greg Duarte
Jun 21, 2018 08:39 AM
bdtaylor1979
Feb 14, 2016 02:04 PM
STREET BOB JOE
Jan 31, 2014 05:43 AM
lowridersioux
Mar 6, 2007 01:39 AM
