Which stainless bolts?
Old Aug 27, 2007 | 08:27 PM
cpa55's Avatar
cpa55
Default Which stainless bolts?
I have seen polished stainless bolts which still have the knurl and show polish stainless bolts which have the knurl ground off. My engine is black with the polished fins and I need some opinions on which stainless bolt would look the best. Thanks for any opinions.
David
Old Aug 31, 2007 | 11:11 AM
GrampsWyatt's Avatar
GrampsWyatt
Default RE: Which stainless bolts?
I'm in process of replacing most of the bolts on my motorbike to the 12 point.Diamond Engineeringhas all diff types polished sst bolts for your bike. Kinda pricey but they are good quality and no more torx bolts is the best thing.
http://www.depss.com/
Old Sep 6, 2007 | 10:49 PM
CDP1911's Avatar
CDP1911
I'm currently installing chromed Bolts:
http://imagehost.vendio.com/preview/...et/P_96_77.jpg
Old Sep 30, 2007 | 03:38 AM
mattro11's Avatar
mattro11
5th Gear
www.alloyboltz.com
I just installed a engine bolt kit from these guys, excellent product, well labeled, and all bolts correct size.
These guys do either curling ground off or polished with original curling.
As a heads up, make sure you put anti-sieze / loctite on each bolt or your never gonna get 'em out again.
Stainless reacts to alloy like a redneck at Woodstock......................
Old Dec 29, 2007 | 01:38 PM
NightTrainRider's Avatar
NightTrainRider
Stage II
I bought the complete S/S polished set (allen head) from diamond engenering for my 2001 nighttrain back in 01 and they still look as good as NEW 7 yrs later, I did put lock tight on all bolts & nuts before installing. The only problem I remember having was that the timing cover bolts were to LONG and I had to cut them down.
Old Dec 29, 2007 | 04:57 PM
JGroves's Avatar
JGroves
ORIGINAL: NightTrainRider
I also used the 12 point Diamond Engineering stuff. It's good but it isn't cheap.
Old Jan 1, 2008 | 12:49 PM
metalhd's Avatar
metalhd
6th Gear
Diamond engineering bolts are some of the best out there. The stock factory bolts will not hold up to the weather/engine heat,and will start to oxidize and developwhite powder deposits. I have seen this on bikes kept outside and in the garage. I have used both the allen head and 12 point on different bikes and they look as new as the day I put them on. Be sure to use Loctite/graphite and torque them properly. Had a set originally on a 95 FXD, switched them to a 99 FXDX and then to a 2002 FXD. No problem.
timberwolfz28
Nov 27, 2013 07:48 PM
Romark
Jan 13, 2013 07:32 PM
Road_Clam
Mar 26, 2009 08:16 AM
larazauk
Apr 7, 2008 12:49 PM
lkbenson
Jun 1, 2006 02:29 AM
