I've had some lying around for awhile but just used them today for the first time on a winter detailing. Loved them! I've always used cotton towels or sweatshirts. But they seemed to make a difference. I'm sold!
Also don't dry them on any heat settings in the dryer. It will melt the plastic and cause them to scratch....
Sorry but if that is happening you have some very cheap mf blends. Even in the process of making MF and the dyes they are boiled. Quality MF has a heat rating of around 500 degrees.....if your dryer does that you are in trouble. Most will dry on a low heat setting so there is no static but static will be gone after towels are cold....a shake will release static anyway.
If you have "MF" that the ends curl I would not use it on paint.
